Oil Pans
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Oil Pans
does any one know were i could buy a oil pan that has the dip stick entry inside the pan. and not iin the block or head....... its for a chevy 350
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
dANG NOBODY KNOWS ANYTHING I NEED HELP MY EXHAUST MANIFOLD IS BLOCKING MY PASSAGE WAY TO MY DIP STICK HOLE......
GM
Get the one for a 78 Monte Carlo, El Camino, Malibu, etc. with a 305. It'll go into the driver's side of the pan.
Get the "gauge and tube assembly" for the same application at the same time.
oil pan w/dipstick below pan rail
I have one, but don't have the matching dipstick and tube. The Chevrolet
parts guy said they were obsolete and no longer available from GM. You can
buy an adapter block which allows you to use the 1980-1985 305 pan or you
could space your manifold away from the head with a spacer which looks like
a header flange. Goodson company sells both of these parts. Your favorite
automotive machinist probably has a Goodson catalog if you can't find it on
the internet.
the internet.
Hmmm.... it's been a few years since I had to buy one of those setups.... guess I better hold onto the ones I have then....
Also, check another dealer.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
skip the middle man and email the sales dept of someone who makes oil pans.
No one sells pistons n rings for Viragos anymore but few emails to totalseal and they made up what is neededand for only $18.50 a set
No catalog or parts seller could of ever done that. SOmetimes its best to go straight to the horses mouth.
Why not just buy an aftermarket dip-stick??? Get a flexible one from transdapt or similar company and then you can mount the top where it is out of the way and it should still leave lots of room under the manifolds for the rest of the assembly.
