305 block...400hp?
Old Dec 17, 2006 | 12:48 AM
Skoda101's Avatar
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
305 block...400hp?
Hello fellow Chevy fans
I was wondering if the pistons,crankshaft(cast), 5.7in connecting rods wil be able to handle 400hp set up? out of a 305 block, it has been rebuilt 1500kms ago but was a pisspoor job and now redoing the task myself and sence it is in pieces before me. Now would be the ideal time to swap stuff out, for my goal hp
Best Regards
Skoda
Old Dec 17, 2006 | 01:01 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Short term, yea it would probably hold up.
I wouldnt plan on using it for a dialy driver, it would pretty much be a ticking timebomb.
Old Dec 17, 2006 | 01:18 AM
Skoda101's Avatar
Car: 1987 GTA
So I'am geussing forged pistons and crankshaft are the way to go?
Old Dec 17, 2006 | 01:31 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes, a forged bottom end and ARP bolts all around (including main caps) and i wouldnt worry one bit about it.
But like anyone else will say, if your going to spend the money you may as well spend it on a 350. A 350 is alot easier to get 400hp out of! A 350 running cast parts isnt too bad @ 400hp, still a bit for a stock bottom end but as long as you dont spin it to the moon it should last.
Old Dec 17, 2006 | 01:44 AM
Skoda101's Avatar
Car: 1987 GTA
I sure this will hold up right http://store.summitracing.com/partde...5&autoview=sku
For the crankshafts I havent found any possible fenders that are forged that seem reasonable in price 300-600cdn
The stock connecting rods will be able to take the pounding?
Thanks for the help
Skoda
Old Dec 17, 2006 | 07:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
423 Flywheel Horsepower @ 6,500 RPM. I have not had the engine in a car yet with this combo, but I bet it would do low 12s in a 3rd gen with traction.
Block = 1983 4-Bolt main 305 (14010203 casting), Bored .040" over, Torque plate honed, Decked .025", ARP Main Studs, Align Bored
Crank = Stock GM Forged Steel (3941188), Lightened, Smoothed, Knive Edged, etc for less windage, balanced with the entire rotating assembly
Bearings = Federal Mogul Speed Pro Coated
Rods = X casting rods, Parting lines ground down, Lightened, Balanced, Shot Peened, Weights Matched, ARP Wave Loc 3/8 Rod Bolts, Reconditioned
Pistons = Stock L69 Hypereutetic Replacements, Flattops with 4 valve reliefs, -6 cc, 0.00" in the hole
Rings - Total Seal Gapless rings
Compression = 10.7:1 with 54cc heads, Zero Decked block, .038" compressed head gasket.
Heads - Ported 2004 ZZ4 castings ("463"s), cleaned up in my garage, final "MAX EFFORT" port work performed by my buddy in his machine shop, .100" longer valves than stock (1.94/1.55 Under Cut Stems, Swirl polished), 5 angle valve job, Forget the exact spring but they are meant for the cam and .100" longer than stock valves, .600 lift compatible. I had to use longer than stock push rods as well. Machined heads for Comp Cams guide plates after opening up pushrod holes in heads. Gasket matched to a Felpro 1206 (1.34" x 2.21")
Head flow @ 28 in/h20 with a 3.75" bore simulator (engine has 3.776" bore).
Lift------Intake---Exhaust
.100------57-------57
.200------123------118
.300------177------162
.400------223------183
.500------229------188
.600------238------193
Camshaft = Comp retrofit roller XFI280-H13 (280/288 @ .006, 230/233 @ .050, .576/.570" lift with 1.6:1 rocker, 113 LSA, 106 ICL) Cloyes Double roller timing set
Intake Manifold = Holley Projection TBI for "OLD" style heads with the same bolt angle. This intake is a dual plane, high rise, with 2" bores. Gasket matched to the Felpro 1206 intake gasket
TBI = TBI unit off of a Heavy Duty 7.0 liter TBI truck, 68# injectors at 32 PSI, 2" bores, thinned throttle shafts, radiused the entrance to the bores, sitting on a 1" tall open center TBI spacer, 720 CFM @ 3.00 in/hg
Headers/Exhaust = Hooker Super Comp 1 3/4" x 3.5" meant for a mid 70s Camaro with a 350. 3" duals with X-pipe (not used on dyno)
Ignition = Stock GM HEI EST small cap distributer (computer controlled) with MSD coil, MSD Module, Moroso Ultra 40 wires, AC Delco Rapidfires @ .045"
Oil System = Moroso Blue Printed Oil Pump w/ Pickup, Moroso Steel Shaft, Moroso 5 quart pan, Moroso Oil Control Kit, Mobil 1 5w20, 70 PSI Z/28 spring
Crankcase Evac = LT1 style Electric AIR pump pulling a crankcase vacuum of about 6 in/hg.
ECM = RBob's EBL with lots of tuning. 34* total advance @ 2,800 rpm.
Dyno Numbers (all rounded to the nearest whole number for simplicity)
RPM------HP----TQ
2,400----147----323
2,600----166----336
2,800----185----347
3,000----207----362
3,200----223----365
3,400----238----368
3,600----263----384
3,800----281----388
4,000----301----395
4,200----322----403
4,400----347----414
4,600----363----414
4,800----378----413
5,000----382----401
5,200----393----397
5,400----401----390
5,600----410----385
5,800----417----378
6,000----421----369
6,200----422----357
6,400----423----347
6,600----419----333
That is 423 FWHP @ 6,500 and 415 ft/lbs @ 4,500.
Old Dec 18, 2006 | 10:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I wouldn't pay $40 a piston for pistons going into a 305. I'd get the cheaper hyper pistons ($9 per) and put them in a 350. Rev it less, get same power, higher HP ceiling for later down the road, etc etc.
Old Dec 18, 2006 | 01:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Absolutely.
As in, swap out that 3.736" bore casting of a block. Swap in a 4.000" bore casting block with appropriate pistons, rod bolts, machine work, rebuild parts.
If you insist on trying to get 400 HP out of a 305, the pistons and crank are fine. If doing a clean-up overbore, the aforementioned hyper pistons would be a good idea ($25ea less than the forged). The rods are a different matter. They need upgraded bolts and precision resizing. Shot peening isn't a bad idea, either.
Old Dec 18, 2006 | 01:56 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I want my 305 to be completely finished. I try not to down on any V8....not even Fords 3.4l V8 in the 99 Taurus SHO. LMAO. Yeah a funny V8 but still a V8. I have the same plan as him and thats building a badass 305. I dont have many to buy a 350 and then start building so I am sticking with my 305 until it is finished or close to what I want. I am looking to have the license plate
350 KLR
Just kidding....but it wouldnt be bad if you had a 305 and wanted to kill 350's with it.
My goal is 527hp.....or 527tq whichever comes first. I know I cant get that type of power out of an LO3 305 but hey Im going to try and get every last bit of power out of this motor.....before I buy a 350....unless I can find a 350 for cheap that has low miles like under 30k or buy a new 350 with 0 miles and baby it for 3k then MASH it on the first person who pulls up 2 me.
Old Dec 18, 2006 | 04:47 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
500+ hp from a 305? Now that's pushin it.
Old Dec 18, 2006 | 06:17 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
No I said I would like that.....its my goal but I know I cant get that from a 305 without....a little buddy......N2O....but I dont want to put that into my car....as of yet
Old Dec 18, 2006 | 06:42 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
that 423fwhp will get you somewhere around high 12's low 13's.. not much torque in your mix..
Old Dec 18, 2006 | 08:22 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Did you not happen to notice that it pulled 320 ft/lbs as early as 2,400 rpm. By 2,800 it is out torquing a Stock L98 350 TPI engine. Peak torque was 415 ft/lbs @ 4,500 rpm.
My Fullsize Van (5,300#) ran 14.8 @ 96 with a 2.18s 60' with the previous version of this engine. With ported 081s and a smaller cam it pulled 301 RWHP. The Van had P295/50/R17s, 4L60E with a 2,800 rpm 10" lockup style converter, and 14 bolt rear with 3.73 gears with an Eaton Differential
Old Dec 18, 2006 | 09:11 PM
five7kid's Avatar
That HP number NA would require spinning that poor thing to the moon - you're talking nothing but high-dollar parts to get there.
The torque # will not come out of a 305 NA - no way, no how.
Whatever you do, you have to stay within the bounds of physics. Some laws can't be broken.
Old Dec 18, 2006 | 09:56 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i've got a calculated 443fwhp from a daily driven n/a pump gas 305 and has been 12.31@108mph and i'm still playing with the tune. it's possible.
Old Dec 18, 2006 | 11:16 PM
five7kid's Avatar
The original question was 400 HP on stock cast parts. Matt, you ain't runnin' stock cast parts.
The "famous" 400 HP 305 magazine article did it on a stock shortblock. Until they grenaded it on the dyno at that power level (don't hear much about that).
And F355, you've done a lot of the "right stuff" to your shortblock as well. Key item: ARP rod bolts (not to mention the rest of the rod work).
The highjack question targeted 500+ ft-lb torque NA. That ain't gonna happen. F355's dyno #'s show 400+ ft-lb NA - impressive, and your #'s will probably be close, Matt, but that's still 25% short of the out-of-the-air # from Mr. HJ.
Reality, people. That's all we ask.
And I still agree with the originator's statement: "Now would be the ideal time to swap stuff out, for my goal hp".
And the least expensive, and arguably most reliable thing to swap out to get there?
The 305 block!
(You don't have to have been around very long to know I'm not a "305 hater". You should also know from very little time here that I prefer to spend the least amount of money to get to a desired goal. "Different" just ain't good 'nuf of a reason.)
Old Dec 19, 2006 | 04:04 PM
mw66nova's Avatar
Engine: 7.0L
i agree whole heartedly with you five7kid, i was just sayting it's possible. and no, i'm no longer running a stock rotating assembly, and forged parts are coming, to replace these ones!
if you want 500ftlbs and you want it cheap and streetable, cubic inches are your friend. while you may think you don't have the money for a new block, you're very mistaken, because even though they are hard to locate, they are truely only like $200 or less. shoot, i've got a 4bolt .060" over 350 block ready to rock and roll right now for sale for $150!
Old Dec 19, 2006 | 05:25 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 305 block!
I also have to agree. Drop a 3.875" stroke crank in a 1 piece rear seal 350 block and have fun.
You can put over 500 ft/lbs to the crank at 3,500 rpm.
Old Dec 19, 2006 | 05:43 PM
Skoda101's Avatar
Car: 1987 GTA
Absolutely.
What I wanted to hear bare with me please through the parts that will survive, list:
Crank
Connecting Rods(with some mod/ new bolts)
-What do you mean by "precision resizing"? that they are blalanced?
For the shot peening process, I'd go to a lacal manching shop for this?
Why keep the 305 your asking... Well sort of a under under dog story, bascily it came out of my dads IROC vert sence he's had nothing but bad results with the engine he said #uck it and now it rest's in my hands with a 1000 dollar bet in the balance that I wont get it working right
Old Dec 19, 2006 | 05:48 PM
Skoda101's Avatar
Car: 1987 GTA
What happened?
Old Dec 21, 2006 | 02:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
precision resizing - when you put on new rod bolts (ARP say), it changes how much it clamps, so you need to resize it. They tighten the new bolts in place, then hone it to the correct size. Once you pay for new ARP rod bolts (say $80), resize ($80), and shot peen ($80), you really wonder why you didn't buy new rods that come with ARP rod bolts, say Ohio crankshaft's $160 specials. That's what I did, and mwNova66 I think.
Those prices for the reworking the stock rods are just #'s out of the air, but you get the idea, it's no exaggeration to say it's CHEAPER to buy new ones, then rework your old ones. There is very little reason to rework your current ones, unless you get a smokin' deal on the rod bolts, and have the machining equipment in your garage (I doubt you do, so...)
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
