305 TPI power?
Old Feb 1, 2007 | 12:51 AM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
305 TPI power?
What kind of numbers are some of you putting down by building up your 305 TPI. Any and all welcome. Just curious. Thanks
Old Feb 1, 2007 | 05:36 PM
Car: 1992 Z28
NObody have any 305 buildups?
Old Feb 1, 2007 | 09:30 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
oh you mean 350 build ups.... yup got a bunch of them...
Old Feb 1, 2007 | 09:55 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
My 305:
Performance Modifications:
Lt1 Cam
LT1 Lifter
Comp Single Valve springs (w. damper)
Edelbrock TES Headers
Taylor Spiro-Pro Ignition Cables
Ported TPI Base
Ported TPI Plenum
Air foil
Iridium spark plugs
3.42 Disc Rear
Visual:
Chrome Timing Cover
Painted TPI System
Painted Rocker Covers
Painted Headers
Not nessecarily performance, but takes away drag:
A/C system removed
Plans:
AS&M Big tube runners
Edelbrock Hi-flo Intake
LS1 driveshaft
Right now its making about 200rwhp
With above mods, should make about 220rwhp.
Could be quicker, but seeing i have spent less then $300 getting all of this together, im going to say its afair bit of engine, for tiny dough.
Sheldon
Old Feb 2, 2007 | 01:34 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
It was a TBI car
Modifications:
LT1 Cam
World S/R torqer 305 heads
SLP Runners
Ported TPI Plenum
Port matched TPI Base
Air foil
3.42 Rear gears
Hooker shorty headers & cat-back
It did 220 rwhp this past summer and it was running a full point rich. With some tuning I think it can get 225-230 easily.
Old Feb 4, 2007 | 12:04 AM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
not sure where to ask this but will headers from a stock LS1 bolt up to a 305?
Old Feb 4, 2007 | 12:32 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
nope, sorry!
Old Feb 4, 2007 | 12:33 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
No, the LS motors have a header tube pattern that is different than older style heads.
LS1 = O O O O
L98 = O OO O
As for 305 power, you have guys on here making between 200-250 rwhp with average modification. If you did the same mods for a 350 youd be closer to the 300 side.
jaridjohn
Jul 8, 2024 03:49 PM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
