shift kit improver !!!! whats the difference?????
Old Feb 7, 2007 | 09:39 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Whats the difference between the 2 in 1 trans pak and the 2 in 1 shift improver kit.......
Old Feb 7, 2007 | 11:22 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
somebody Please
Old Feb 8, 2007 | 04:54 AM
jax1-2's Avatar
i was wondering this as well, anybody know?
Old Feb 8, 2007 | 10:43 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
some help would be much appreciated
Old Feb 8, 2007 | 09:05 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Im assuming your talking about the B&M kits, which are absolute garbage, trust me. Buy a TransGo kit.
Old Feb 9, 2007 | 10:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I think the shift improver is just like it sounds you will get a crisper shift and the transpak is a hard shift with the manual shift option.
Old Feb 9, 2007 | 10:55 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
are they both easy to install????
Old Feb 9, 2007 | 11:13 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
depends how good you are with instructions and hand tools. Myself I dont screw with that stuff. send it to a tranny guy and have him do it then if something goes wrong its on him.
Old Feb 9, 2007 | 01:58 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Well i have a tranny guy doing it and hes been doing chevy tranny for about ten years but hes never installed a shift kit...
Old Feb 9, 2007 | 02:12 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
If he is a tranny guy and has never done a shift kit then take it somewhere else!
When i worked at the tranny shop it was always good practice to install shift improver kits and/or valvebody modifications. Keeps them from coming back.
He is probably one of those guys that doesnt clean the valvebody because he doesnt remember the correct way the parts go back in.
Old Feb 9, 2007 | 02:24 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
The trans-go kit is the one to use. It requires a fair amount of basic knowledge on transmissions. Not saying you cannot do it, but it takes about 2-4 hours and while not complex, you have to be careful with check *****, springs,etc. The instructions are well laid out. I suggest you go to TransGos website and you can download the instructions. Then you can decide if you want to tackle the job. Badman
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
Naw its just that hes been working at the dealership his whole life and at a dealership you might know that they dont deal with any type of aftermarket work.........
Old Feb 9, 2007 | 02:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
In my honest opinion, take it to a transmission shop with shift kit experience. My second piece of advice would be to get a TransGo shift kit.
Old Feb 9, 2007 | 03:45 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i am in the same dilemma myself with a 1977 th350 trans in a truck of mine it needs an improver kit it has a weak third gear(shifts into but doesnt hold it very well) and im pretty sure its due to a leakage past a seal, i was told its the third and reverse pistons seal or something like that and that i could at least temporarily resolve the issue by installing parts of the shift improver kit but not all of the kit
ive taken a few th350 trannies apart but never reassembled one, ive still never figured out how to learn how the parts in them work and what they are no matter how muh i look at manuals and such its just a whole diffferent world than engines are in which are simple to rebuild compared to trannies imho
no trans shops here, id have to travel a ways to get to one and it wouldnt be worth the cost anyways plus its in a 4x4 and its a ton of work to get that super heavy iron 203 transfer case out of the way to swap another trans in it in which would take alot of $ to replace with a known good one, if such could be found
dilemmas suck...
good luck
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
