steel vs alum heads
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
steel vs alum heads
I've got a set of steel heads and also a set of 113 alum. corvette heads, both from 89 tpi's. just how much better are the alum. heads vs steel heads. i'm concerned about stripped spark plug and other holes, and header bolts backing out.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
both will make the same power essentially, the alum can run slightly higher compression but that's about it. Figure 2% for that added 1 compression point
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Didn't the vettes have higher flow numbers? I could have sworn I remembered reading this.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Yes, I've read it as well, pretty recently too. Will see if I can find the reference within the next few days...
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Barely higher flow numbers, hardly enough to wiggle the needle on a dyno. Remember, the F-body and Corvette 350's both had the same camshaft and TPI intake manifold. The only difference was the heads, and the horsepower difference was either 5 or 10, depending on year.
Transmission: 4L80E/4L80E
And the HP difference had more to do with exhaust than the heads. The weight savings helps performance a little, but not power.
Either head needs some porting to get the most out of them. They also have intake mount bolt angle and cross-over passage differences (the aluminum not having the passages).
Guest
Posts: n/a
It's a chicken/egg thing. Aluminum loses more heat, heat = energy, energy = power, so the compression is raised with aluminum heads to regain the lost power.
Car: 1984 Z28
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am putting the vette heads on my car so I can save 50lbs.
Aren't the vette heads 58cc while the iron L98 heads larger, which would mean you would get a little higher compression on an L98 when you put the vette heads on? I know on my 305 with 58cc iron heads that my compression will stay the same, so I don't get any boost in power in that area.
Well, you could say the iron L98 heads are 64cc and the '86-1/2-up Vette L98 aluminum heads are smaller, giving the aluminum headed engine the added compression needed to make up for the heat loss through the aluminum material.
Other than the weight savings, it's a zero-sum game.
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Exactly.
There might be a slight benefit from the 1.94" intake valves, but with 1.94" intake valves in the stock iron heads, you'd get more power.
It's all about where & how you want to spend your upgrade money.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Suppsedly the aluminum L98 heads will only perform well once they're ported, stock ones are anything but impressive.
Here are the flow#'s https://www.thirdgen.org/forums/tbi/...-headflow.html
David Wizard writes in his book regarding porting/modifying Chevy heads, the aluminum L98 heads are ok if you can find them real dirt cheap or if you already have them, however one major issue is their low weight, due to their thin casting.
That's why they weigh in less than aftermarket aluminum heads, thin casting vs nice thick aftermarket casting.
Also, which ones are these, the "standard" exhaust port or the raised one ?
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
