damaged return line
Old Feb 16, 2007 | 11:45 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
damaged return line
I am just about done with my engine swap. (89 305 tpi)
The return line was damaged during the motor pull.. It is pinched, probably about half to a quarter of the diameter it should be. My question is, how will this effect the fuel pressure, and will it cause pump damage. (I have a feeling I already know the answer). The car is almost running... Please advise.
-Brendan
Old Feb 16, 2007 | 11:54 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
You shouldn't run it like that, cut the damaged section out, and fix it with a coupling.
Old Feb 17, 2007 | 11:53 PM
Toehead's Avatar
Thank you
Old Feb 18, 2007 | 03:35 PM
Toehead's Avatar
Does anybody know the correct size coupling to use? I am at school and have no access to my car. I figure I'll get the parts now and get a jump on the situation.
Old Feb 18, 2007 | 04:45 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I think I read a post with metric sizes, I measured them to be 3/8" supply, and 5/16" return, I'd double check it.
Old Feb 21, 2007 | 09:10 AM
Toehead's Avatar
Ok will do..
Anybody have any tips for cutting the line? Ideally I would use a copper pipe cutter, but I don't think I could fit it in there. I'm not sure of any other way to cut it without making sparks and shavings. Any ideas? tricks of the trade?
Old Feb 21, 2007 | 09:42 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
How much room is there around it? Can you take a picture? I have an idea, but need to see where the damage is at.
Do a search for
Carbide Gritted Rod Saw(Diamond Wire)
Old Feb 21, 2007 | 09:53 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Any pipe cutter should work. They don't cost much and are very small. Mine is about the size of a car lighter.
Old Feb 21, 2007 | 10:11 PM
Toehead's Avatar
pretty much no room. I havnt disassembled anything yet, but it looks like I will only have a half an inch. If you look at your tpi setup, the fuel return line is damaged where it runs parallel to the passenger side fuel rail.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
scottmoyer
Sep 7, 2015 07:06 PM
TBRays98
Sep 6, 2015 05:05 PM
