bad overheating
Old Mar 8, 2007 | 08:52 AM
hotrodZ28's Avatar
Car: 1991 Z28 camaro
Engine: 5.0L 305CID V-8
Transmission: 5 speed
bad overheating
hey, this is kind of a stupid question my car has started overing heating bad if the thing idles for ten minutes its boiling any ideas?
Old Mar 8, 2007 | 08:56 AM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
are the fans runing? is it low on coolant? you men when its cold and then runs for 10 mins it is aready boiling?
Old Mar 8, 2007 | 04:24 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
is your air dam still there? My friends airdamn came off one day and its surprising how fast these cars can over heat without an airdam.
Old Mar 8, 2007 | 04:28 PM
B&WIROC's Avatar
i second that on the airdamn you need this no mater what! mine came off a few weeks ago and i couldn't drive around the block before it started over heating like crazy. check to make sure none of your coolant lines are pinched closed. there's some sleeves you can get from your basic autosupplier that help keep the hose open on tight bends if you need them. they're like 5$.
Old Mar 8, 2007 | 04:36 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
First: check coolant level,
Second: make shure the fan/fans are coming on,
Third: take the t/stat out and replace it,
Forth: come back and tell us if it is still doing it.
Hope it helps.
Old Mar 8, 2007 | 04:51 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
how hot are we talking about here? boiling at 212 or 220? you are running 50/50 anti freeze right? and buy a new radiator cap!
Old Mar 9, 2007 | 07:10 AM
hotrodZ28's Avatar
i have done everything i can think of changed t/stat, waterpump, flushed the system, the air dam is still there(and works fine as far as i can tell) fans are fine and it still goes from cold to about 220 in about ten minutes
would the radiator cap make that much of a difference
Old Mar 9, 2007 | 03:43 PM
Car: 91 RS
Engine: 350 vortec
yes it isnt as cold in NC so i could see it getting warm pretty quick and yes a radiator cap will allow the motor to boil at a lower temp than the system is designed to maintain as in your fans turn on at 238* and cool til about 195 and as we all know water boils at 212 but with anti freeze and a 15psi rad cap that will raise to over 260... sorta like a pressure cooker the pressure raises the boiling point of the water ...
Old Mar 9, 2007 | 03:55 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You've covered most of the bases so far. I'd next check airflow through the radiator and water flow through the cooling system. You can pull off the top radiator mount to have a look between the condenser and radiator. It will get clogged up with trash over time. Make sure you've got the right water pump for your belt routing and water is flowing through the radiator.
Old Mar 11, 2007 | 10:07 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by hotrodZ28
...and it still goes from cold to about 220 in about ten minutes
Only the most commonly overlooked component of the cooling system. If the cooling system does not go under pressure, the coolant will not stay in the system.
Heck, I hear that radiator caps are pretty cheap and easy to replace ...
Don't feel bad if that's the problem, you won't be the first.
If the system goes under pressure with the fans on and loses coolant then the head gasket(s), water pump, or radiator is bad.
Old Mar 11, 2007 | 11:40 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Is the engine actually heating up that much, that quickly or are you relying on a 20 yr old dash temp gauge? Try to get an acurate temp reading - I would not rely on a dash gauge.
Corky
Old Mar 12, 2007 | 07:52 AM
hotrodZ28's Avatar
thanks ya'll it was the cap and i had to do a little work on the fans
Bubbajones_ya
Jul 6, 2024 08:32 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
