Neutral safety switch
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Hi
I think I have a faulty neutral safety switch on my 91 formula 305TPI. Where is that located? I don't think that it will be that hard to replace, only if I knew where it is?
Thanks, any help will be much appreciated.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Neutral safety switch
It's right on top of the clutch pedal assembly. It's a large black rectangular push button type switch with thick wires going to it, yellow and another color, if I remember correctly.
Engine: 305TPI
How does the clutch engage it then if it is in the shifter area?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
haha well guess he has a manual trans then
in that case its a clutch safety start switch, not a neutral safety switch
and usually its on the clutch pedal linkage under the dash, or on the tranny(possibly but probably unlikely in these cars)
Engine: 305TPI
Thank you for you replies. I will try to take care of this over the weekend. I had to push start my car today.
Engine: 4.3L Z TBI
jumper the yellow and purple wires together, they are larger wires, stranded copper, under the dash near the pedals, single connecter, two spades
Randomtask2
Sep 10, 2015 08:37 AM
