making a 383 stroker
Old Mar 23, 2007 | 07:48 PM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
what all do i need to make a 383 stroker out of a 350 sbc i already have the machine work done to the block it is .06 over
Old Mar 23, 2007 | 07:59 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: making a 383 stroker
first off, a 383 is a 3.75" stroke with a 4.030" bore.. you will be building a 388.. here is what you need:
stroker crank with 3.75" stroke and 350 mains(bearing size)
either 5.7" or 6.0" rods
4.060" stroker pistons made for a 3.75" stroke and the rods you will be using..
i would just find a stroker kit that is available with .060" over pistons.. balancing is another issue.. you have to buy your flywheel/flexplate and harmonic balancer in either internal balance or external balance.. which ever your rotating kit requires..
Old Mar 24, 2007 | 12:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont forget, you also need LOTS of money to build it, and LOTS of time to get it done.
Old Mar 24, 2007 | 01:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Really? I thought they're pretty easy to do? I mean, just like a 350, but the crank is slightly funnier shaped. And sometimes you have to grind a bit of clearance into the block, and maybe use a small base circle cam.
Old Mar 24, 2007 | 03:18 AM
Gramps's Avatar
Car: 87 Camaro IROC
i just did a mach price buildup of my 383. itll be costing over 7G's CDN. thats including porting, machining, and custom parts. plus i just HAD to get the fancy expensive **** to keep the pesants happy
Old Mar 25, 2007 | 02:15 AM
Kevin91Z's Avatar
To do it the RIGHT way, you need special 383 pistons, special 383 rods, a smaller base circle camshaft, special balancing, and special grinding in the block. That all adds up to lots of money and lots of time.
Yes there are cheaper 383 engines out there, but you get what you pay for.
Old Mar 25, 2007 | 02:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
Well I guess so. Having never built one, I can't really argue with you and stay credible.
I figured the block grinding was something you can do at home with a die grinder. So for most of us, free.
383 pistons I think are virtually the same price as 350 pistons now.
383 rods are usually the normal 5.7" rods, assuming you're using the 383 pistons. Capscrews make for less block clearancing, but I don't *think* they're needed.
Small base circle I think can be about the same price, or pretty close. I think this one is also not needed always.
Balancing - you've got me there. Balancing a 383 always threw me off, internally it's expensive, externally it's not too bad.
Apeiron nearly convinced me to do a 383 when I rebuilt my 350, telling me it was exactly the same price. I figured since it was the first motor build for me ever, I should add ANY additional complications. Also, ported 416 heads are ok for a 350, but a 383 would be pushing it. Just couldn't do it justice.
Old Mar 25, 2007 | 12:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The cost of parts is comparable between building a 350 and a 383. A moderate flat tappet cam will usually clear a set of stock rods with ARP bolts. More aggressive cams or rollers may need a smaller base circle or clearanced rods. There's no difference in the balancing, it's done the same way for a 350 and 383, unless you want an internally balanced 383.
What does take time is the clearance work. The rotating assembly has to be assembled one cylinder at a time, interfering areas identified, the block taken down again and ground for clearance. Then the entire block has to be completely cleaned again to remove the debris, and the whole process started over again.
Old Mar 25, 2007 | 09:56 PM
5678TA's Avatar
Car: 1984 Trans Am
there is no right or wrong way to make a 383..
no need for special rods or a small base circle cam.. i bought a cam straight out of the catalog.. worked with NO interference problems.. the only special parts you will need are pistons.. the rest is just grinding to make it fit together nicely..
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
