wont turn over only clicking.....
Old Mar 24, 2007 | 10:39 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
got in everything goes on like usual (dome light radio infl rst etc) go to turn it on CLICK everything shuts off. Its holding an extremely weak charge just enough for the dome light to be barely lit and a weak alarm. Every thing powers back up when I hook up a jump to it, but wont turn over, it just gives a series of rapid clicks. take off the jumps everything turns off.... any ideas... short? fusible link? someone give me an idea where to look for shorts or location of a fusible link
Old Mar 25, 2007 | 01:00 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: wont turn over only clicking.....
Have you checked to be sure battery cables are tight and not corroded? Might try getting the battery tested for a bad cell. My car did this exact thing recently and it was a bad cell in my battery.
Old Mar 25, 2007 | 01:05 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
I agree, make sure the terminals are not corroded and if that does not work get the battery tested. I would bet you probably have a bad cell though.
JAy
Old Mar 25, 2007 | 01:23 AM
ChoobinatoR's Avatar
Sounds exactly like the starter solenoid has enough power to pull but not hold in, this with the dim lights, you gotta bad battery for sure man. Well maybe not bad, but it's definently dead. Use a volt meter on it if you got one, parasitic draw [check for amps with ignition off/all lights off], or a problem in the charging/starting circuit is at fault here. Good luck.
Old Mar 25, 2007 | 02:11 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
dead battery and/or bad alternator.. get the alternator checked.. and corrosion like the others said..
Old Mar 25, 2007 | 04:17 AM
zcarz's Avatar
Car: 1989 IROC 5.7
Engine: 1989 5.7 TPI
Battery is the most likely problem. When you try jumping it make sure you are using heavy enough jump leads and hook the negative lead to the chassis or engine on your car, not the negative terminal on the battery. A dead cell in your battery will absorb a large portion of the jump battery's charge and may not allow enough charge to start your car. A battery shop can check for a dead cell in a few minutes and usually at no charge.
Old Mar 25, 2007 | 11:14 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by zcarz
...When you try jumping it make sure you are using heavy enough jump leads and hook the negative lead to the chassis or engine on your car, not the negative terminal on the battery...
That's always the engine, never the chassis or negative battery terminal.
If your jumper cables are good and the battery is bad, or the negative cable is loose on the block, you will smoke the frame ground straps shown here. Ask me how I know...
Attached Thumbnails wont turn over only clicking.....-100_0231_c.jpg   wont turn over only clicking.....-100_0232_c.jpg
Old Mar 25, 2007 | 12:00 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
thanks guys.... ill check it out. Battery is new (11/06) but I kinda had a feeling it was toast.
Old Mar 25, 2007 | 08:57 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
yup its dead
Old Mar 25, 2007 | 10:04 PM
New battery that went dead? Did you find out the source of the problem? Usually a dead battery is a symptom of something else...
Old Mar 26, 2007 | 02:12 AM
90IROCJustin's Avatar
Car: 1988 Camaro (Z28 Clone)
Engine: 305 4bbl roch
you should check all your wires and your starter too
Old Mar 31, 2007 | 11:13 AM
raven0840's Avatar
Car: '83 Camaro Z-28
Engine: 350 Crossfire
Axle/Gears: 3.23 posi
In diagnosing a "bad" starter (turns out it was a loose battery connector), I heard that if the starter solenoid goes bad, it'll click but not crank. One recommended temporary fix was to tap the starter. Supposedly, this would bring the brushes in the solenoid in better contact and you'd get another start, maybe two out of the starter. Also, when you're testing stuff, be sure to check BOTH current and voltage. This is why I didn't realize the loose battery terminal. The bad connection still delivered 12v to the starter, but insufficient current to crank the motor. Certainly not the opinion of an experienced mechanic but it would seem to make sense.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
