are these heads worth a ****
Old Mar 27, 2007 | 08:58 PM
BadIROCZ's Avatar
Car: 89 Iroc Z
Engine: Gen 1 350
Axle/Gears: Stock and shitty
i got these heads for free the number is 3998993 i know they are 76cc but how do they flow do they respond to porting?
Old Mar 27, 2007 | 09:03 PM
ljnowell's Avatar
Re: are these heads worth a ****
they are basically garbage. The exact same as an 882 head, for the most part. they came on a lot of the low hp work van replacement motors. They can be ported, and cut for bigger valves and then then use domed pistons, etc. And when you get done spending lots of cash, you will realize it wasnt worth it. I usually give those heads away to people just to get them out of the garage when we do an engine swap on a smog engine.
Old Mar 28, 2007 | 09:29 AM
They are worth less as heads, than as cast-iron. Someone actually ruined the iron by turning it into those. Hard to believe I know, but true.
I have actually paid somebody to come haul off piles that had some of those in it, just to get them out of my face, at various times... those, and 882s, and 624s, and 434s, and 2-barrel intakes, and various other useless cast-iron crap that found its way onto my property by being attached to something worthwhile, and took up residence. Kind of like cockroaches or something.
Old Mar 28, 2007 | 10:52 AM
irocz286's Avatar
Car: 1986 Camaro IROC-Z
Engine: 355ci, AFR Eliminator Heads etc...
Transmission: 700R4 Woooorked
Axle/Gears: 3:42 with Eaton LSD
Hey all, i've got a similar question. I have a set of heads casting #14014416, I know they are a 58cc chamber but anybody know the flow? Thanks
Old Mar 28, 2007 | 11:08 AM
Pitiful, in stock form.
They are 305 heads with 1.84" intake valves.
However, with 1.94" valves and competent home porting, they can get up to the 220ish range; and mid-high 230s with professional porting. Their chambers end up quite a bit larger, usually 62-63cc or so, by the time they get to those flow numbers (unshrouding).
Old Mar 28, 2007 | 11:16 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
The 416s are allegedly in the 190's intake flow at 500 lift stock. There are worse.
Old Mar 28, 2007 | 12:59 PM
irocz286's Avatar
So if I were to go lookin' what would be the best numbers for some 305 heads that i'm gonna do a little project with? Thanks
Old Mar 28, 2007 | 02:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Best numbers ? Like best HP numbers you could get with 305 heads? Probably in the 350-370HP range. I think i'm in the 350HP range with my full on ported 416 heads.
I used my old 993 heads as practice for porting. Plus the 1.94 intake valves I stole and used in the 416 heads. Very nice.
Old Mar 28, 2007 | 02:56 PM
irocz286's Avatar
I'm plannin on doing about the same thing with mine, What size cam are you runnin in yours? Thanks
gta90
Sep 15, 2015 04:00 PM
Streetstuff
Sep 7, 2015 09:23 AM
509 camaro fan
Sep 6, 2015 10:43 AM
earlpote
Aug 28, 2015 10:42 AM
