ZZ4 113 aluminum heads & which spark plug to use
Old Apr 13, 2007 | 02:29 PM
pr1689's Avatar
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
Well, I had got these plugs from the Chevy Dealer when I went in and asked for a set of plugs for my heads. They gave me AC Delco FR5LS. After reading a thread here on the board, it stated to use A/C MR43LTS
What plugs do you all recommend that I use with those heads (aluminum 113 heads) 10.5:1 ratio, TPIS big mouth intake, etc. Can I use any of the Bosch Platinum +4 plugs? Is that even recommended?
Thanks,
Pat
Old Apr 13, 2007 | 03:48 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: ZZ4 113 aluminum heads & which spark plug to use
My work sells the bosch +4's THEY ARE CRAP, waste of time and money, just get ac delcos, bosch plugs just have more tips to burn off, i would nt sell em to anyone
Old Apr 13, 2007 | 03:50 PM
pr1689's Avatar
Car: 86 Iroc Z28
Ok, thanks for your reply, that's good to know. By chance, does anyone know which AC Delco plug to use with these heads?
Thanks,
Pat
Old Apr 13, 2007 | 04:23 PM
Dr G's Avatar
Does anyone know if the ACDelcos that are in the ZZ4's when they are shipped are 'good enough'? I'm going to start my newly installed ZZ4 in the next few days and was going to use them.
I could post the part number tomorrow when I get a chance to check it in the garage.
Edit:- The plugs supplied with the engine from GM in mine are AC. MR43LTS.
Old Apr 13, 2007 | 04:47 PM
pr1689's Avatar
Car: 86 Iroc Z28
Well I spoke to one of the parts guys at my local Chevy Dealer, (one of the most knowledgeable), and he looked this up and said that there are 2 options for the plugs.
The fr5ls and the mr43lts and then added that the m43's are for marine and aluminum heads.
So it looks like those are the correct ones for the Aluminum 113 castings. Now my question is exactly the same as Dr G's. Are those good plugs to use or is there something better to use with this setup? It's a ZZ4 build.
Thanks,
Pat
Old Apr 13, 2007 | 05:52 PM
Guest
Guest
Posts: n/a
Those are the plugs the factory put in those heads. They're fine.
Old Apr 13, 2007 | 08:27 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I got the AC Delco 41-906 Iridium. With the MSD 6A and the Blaster coil and MSD 8.5mm wires I gapped them at .085 and this thing gets up and flys! MSD recomends a gap from .045-.065, but that's with regular plugs. With the Iridiums, they can be gapped larger due to less resistance. Plus the wires only have 40-50 ohms per foot.
Old Apr 13, 2007 | 08:33 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
plus no home mechanic is able to gap iridium plugs that is why gap is included in the part number as changing the gap ruins the plug... besides iridiums are for RICERS R' US
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
