Cam and Timing Set Problems
Old Apr 16, 2007 | 07:54 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Hey,
Im sorta in a bind right now and need help fast!! I bought a retro-fit camshaft for a roller 350 block that I have, thinking that it was a roller cam. Now, When I go to install my camshaft, I cannot use the stock thrust plate, because my cam doesnt have a snout or a step for it to go through the plate in order to get my cam sprocket on. I bought a cam button and lock plate now, but I don't know which timing set to buy, any recommendations???
Thank you
Chris
Old Apr 16, 2007 | 07:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam and Timing Set Problems
Only a timing set for a non-factory roller cam will bolt to your retro roller cam.
Old Apr 16, 2007 | 08:02 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
yeah i tried one for an 1980 chevy with a 350, but it turns out that the middle hole for the button is too small for the button to go through. I forgot to mention that I have a 350 vortec motor if that helps
heres the cam
http://store.summitracing.com/partde...8&autoview=sku
heres the button I bought
http://store.summitracing.com/partde...2&autoview=sku
thanks!
Old Apr 16, 2007 | 09:21 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
K here is are 2 better questions:
1) In which order do the cam button and lockplate go in? Is it
a) Cam-->Gear-->Button-->Lockplate?
b) Cam-->Gear-->Lockplate-->Button?
2) Is the cam button supposed to be flush with the cam sprocket or is it supposed to be sticking out??
Old Apr 16, 2007 | 10:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you use a lock plate, it goes in after the cam button.
Old Apr 17, 2007 | 12:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
2.) No, the cam thrust button is supposed to have it's nose sticking out. That is what prevents the camshaft from "walking" forward. It sticks out to hit the back of the timing cover.
Old Apr 17, 2007 | 06:04 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
just figured it out today, just needed a bigger hole in my cam gear for the cam button to go through.
thanks for everyones input!
Old Apr 17, 2007 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're not using a stock timing set, are you?
Old Apr 17, 2007 | 06:44 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
nope, but i believe its for a older sbc. I got one that is made for retro fit cams.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
