xe268 or crane 2050
Old Apr 26, 2007 | 01:21 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
xe268 or crane 2050
I've got a cc'd 84 trans am HO w/700R4 (stock converter) and 3.73's. I'm rebuilding a 350 with about 9.3comp, with either vortech or s/r torquer heads. I want to keep all emissions intact, unless I get the vortech heads which don't have egr. I need to pass emissions, so i may go with the s/r torqers and have some porting done. Anyways, here are the cam specs:
crane 2050
duration at .050 int/216 exh/228
lift int/454 exh/480
xe268
duration at .050 int/224 exh/230
lift int/479 exh/480
What do you guys think?
Old Apr 26, 2007 | 01:52 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: xe268 or crane 2050
XE268
Old Apr 26, 2007 | 06:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I had the 2050 back when it was a 305 instead of the current 350. It passed the dyno sniffer without problems. Needed about 2800 stall, I had 2300.
I think I'd go with the XE268, though.
Old Apr 26, 2007 | 07:09 PM
84 t/a 5.0's Avatar
cool, so you think I won't have any issues with emissions with this cam?
Old Apr 26, 2007 | 08:32 PM
five7kid's Avatar
As long as the O2 sensor is fresh and the ignition is up to snuff, no.
Old Apr 26, 2007 | 08:47 PM
84 t/a 5.0's Avatar
yeah, everything is new from the last rebuild I did a little over a year ago. thanks for the help
Old Apr 26, 2007 | 09:00 PM
bhmabob's Avatar
Car: 1992 trans am convertible
Engine: 355 TPI AFR heads superram
Transmission: tremec TKO500
Axle/Gears: Auburn 3.27 9 bolt posi
what type of intake mods do you will you have? I had that cam(xe268) in a 383 vette '79 carbed, and for the relativly short duration it will rev. trick flow 180 cc twisted wedge heads and a3.55 gear it went mid 12's shifting it around 6700. youll love the power it will make if you give it a big enough intake!
Old Apr 26, 2007 | 11:25 PM
84 t/a 5.0's Avatar
well i was thinking of running the edelbrock performer, not sure if any bigger will clear the hood. i'll have to look into it.
Old Apr 27, 2007 | 01:54 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The performer RPM clears fine. I'm using that with a q-jet on top in my '82 TA with powerbulge hood. But the stock air cleaner. So if you stick with that height of air cleaner, it'll fit.
Hotrodboba400
Dec 10, 2019 07:07 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
