CNC-MotorSports Short Blocks; Anyone?
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I'm looking to move to a 396 in my 96 LT1 and have been doing some internet searches.
I found CNC-MotorSports offers one with all forged internals - Eagle 3.875Crank and 6" Rods and SRP pistons, fully assembled. Price is pretty good too.
I'm wondering if anyone is running one of their engines and can give me some feedback.
Thanks,
Jake
Thanks,
Jake
Axle/Gears: 3.07
Re: CNC-MotorSports Short Blocks; Anyone?
Over the years I've seen my share of cast BB cranks that had cracks right at the journal fillet when magnafluxed. I've also read a couple of posts on other Forums of guys snapping a LT1 rod right in the center and more than a few stories about spun rod bearings.
I've haven't seen the actual numbers, but I read once that GM tightened the rod bearing clearance on the LT1.
I recently read an article of how a spun rod bearing is one of the weaknesses of the LT1; apparently it happens somewhat frequently.
Jake
Car: camaro
Engine: 383
Transmission: 350 turbo
i bought a rotating assembly from him. bal to the flywheel 1206.00 to the door. srp pistons, total seal rings, eagle crank and rods. 383 for 1 peice rear seal. no bad things to say about him. google the guy's name and see what comes up. it's basicly a machine shop that sells products that it makes. A+ in my book. will definatly reorder again for my next engine.
Axle/Gears: 3.07
Jake
Car: '82 Z28
Haven't run one of thier engines but have bought my rods and a carb from there. No complaints and good prices.
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
I've been looking at Their 383 shortblocks myself. I wanna go with 396 setup but I can only afford the completely forged 383 with 9.8 compression. It goes for about 3,200 with the roller cam+timing chain installed. I wonder if they actually have a warranty on their shortblock's though....
Axle/Gears: 3.07
I bought a set of ported AFR heads and quite a few other items - all new - from another guy in Florida. He also has a FRESH 396 short block, which I believe is a LT1 based engine too. If you're interested in it, I'll try to find his email address for you.
He had it up for sale on EBay with a starting bid of less than $2,000. Unfortunately, for me, I'd already committed to buying the SD before I found it. I don't know if it has been sold yet though.
Both sellers are stand-up guys to deal with.
Let me know.
Jake
wigmobile
Feb 26, 2025 02:56 PM
RyanJB
Sep 14, 2015 03:39 PM
