HEI Distrib.
Old May 3, 2007 | 04:56 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
HEI Distrib.
How can you tell if you have a timed vaccum or full vaccum dizzy? I'm trying to time my 350 and with the dizzy unplugged, around 10 deg. advanced runs great, after i plug the vaccum line back in, it backfires nonstop.
Old May 3, 2007 | 05:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HEI Distrib.
"Timed/ported" or "full-time" vacuum refers to the vacuum source on the carburetor. It doesn't have anything to do with the distributor itself.
Old May 3, 2007 | 06:55 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: HEI Distrib.
So should i plug the distrib into the timed or full vaccum port on my edelbrock 1405?
Old May 3, 2007 | 07:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: HEI Distrib.
Your call. Depends on the motor build, some engines run best with ported vacuum, some prefer manifold. You tune it to run well on one or the other, but there is no real "right" or "wrong" way, all personal preference.
I'm not sure why it would backfire when you hook it up, but at least you know that is a full vacuum source.
Old May 3, 2007 | 07:20 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: HEI Distrib.
Well i had it disconnected while i was timing the motor. when i got it around 10 deg. i plugged it back in, i watched the mark on the balancer keep moving until i couldn't even see the mark while looking behind the water pump.
Old May 3, 2007 | 07:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: HEI Distrib.
Yea, it'd be up at around 30* or so. It shouldn't really backfire with 30* of timing at idle though. *shrug*. Oh well, leave it with timed eh ? See how it runs then.
Old May 3, 2007 | 07:48 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: HEI Distrib.
about what should base timing be around? It's a rebuilt 350. I'm assuming its a little better than stock, with a edelbrock torker II single plane intake and edelbrock 1405 600 cfm carb.
Old May 3, 2007 | 07:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: HEI Distrib.
Check out the HEI primer in the tech articles.
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
