fuel pressure problems!
Old May 11, 2007 | 02:33 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
im running a carter electric pump and a mallory 3 port regulator on my 383. The pump says it good up to 8 psi but for some reason i cannot get anymore than 4.5 psi according to my inline guage. After i drive it or let it idle for 5-10 min. the pressure drops down to around 0-1 psi. The screw is as far down on the regulator as it will go and it max out at 4.5 when first started. I checked the fuel filter and it was in good shape. The electric intank pump has been removed so its free flowing, whats the problem here? I took the fittings off the regulator and cleaned some tape out of it but it didnt seem to make a difference. I dont believe it is vapor lock because my pump is far away from my exhaust and any heat source. Anybody have any ideas?
Old May 12, 2007 | 07:53 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Re: fuel pressure problems!
anybody?? Ran a hose from the fuel pump to the regulator outside the car and the pressure still drops to around 3 after idleing for 5-10 min. I guess that eliminates vapor lock. Anybody else have any suggestions? Do these regulators go bad often, its new so i hope not!
Old May 12, 2007 | 09:02 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
could you have damaged the regulator by bottoming the adjustment screw?
Old May 13, 2007 | 06:14 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
You arent supposed to bottom out the adjustment screw?
Old May 13, 2007 | 06:30 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
try screwing it the other way.. i dont remember how my holley regulator works but i screwed it in one way and pressure went opposite of what i wanted.. keep playing around with it..
Old May 13, 2007 | 11:21 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Why do you need the regulator?
I would look at the inlet (feed) side of the fuel pump for a soft or kinked collapsed fuel line (heat) or maybe junk in the pump. Most of the carter electric pumps do not require a regulator. Which model pump do you have
Old May 13, 2007 | 01:35 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
i see no problems with the fuel line. The pump is a carter P4600HP. When i start the car up cold, the pressure jumps up to 8psi and slowly bleeds down as the car warms up. I took the regulator out and ran a straight hose and it did the same thing. Hooked a volt meter up to the pump and it read 11.9x. Anybody have anymore ideas?
Old May 13, 2007 | 10:49 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
I switched to a holley blue fuel pump and set the fuel pressure at 7psi and took it for a 10 min drive, came back and it was still at 7 psi. I let the car idle for another 5-10 min. and the pressure slowly dropped down to 4.8-5 psi. Is this normal?
Old May 13, 2007 | 10:51 PM
Car: 91 RS
Engine: 350 vortec
are you pumping through a inline filter after the pump?
Old May 13, 2007 | 10:56 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
yes it is after the pump.
Old May 13, 2007 | 10:58 PM
Car: 91 RS
Engine: 350 vortec
clean it or replace it and i bet your pressure problem goes away
Old May 13, 2007 | 11:03 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Its new! I took it off and checked the filter and it was as clean as it gets.
Old May 13, 2007 | 11:07 PM
Car: 91 RS
Engine: 350 vortec
okay is the filter made to be pumped through or is a drawthrough?
Old May 15, 2007 | 09:46 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
He is getting a voltage drop. When you're on the gas, voltage is good, around 13V, maybe a little more. Stop the car and let it idle, fans come on, voltage drops to something like 10V. Thinking this may be because of underdrive pulleys, not sure yet. I know on my firebird, fans on, my voltage is still around 13V. Like he said with the Holley pump, starts at 7, after idling for a while (or come back from a drive and idle it) then pressure is around 4-5. With the carter, pressure starts off ok, drops to almost nothing. Seems like even 9 or 10V should be enough to push even a few psi?
If I have him hold the gas so the voltage rises again to 13V, the pressure doesn't seem to rise again, stays around 4-5psi with the Holley pump, where initially it was 7. Dunno.
Old May 15, 2007 | 10:12 PM
Car: 91 RS
Engine: 350 vortec
where are you taking the pressure readings?
Old May 15, 2007 | 10:22 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
right before the duel feed into the carb (after the regulator)
Old May 15, 2007 | 10:25 PM
Car: 91 RS
Engine: 350 vortec
okay well you should test the pressure before the regulator if possible or both at the same time would be great help point the finger in the right direction at least
if both pumps are doing it, it probably isnt the pump.
what kind of a pickup are you running in the tank
Old May 15, 2007 | 11:14 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
It's a straight tube (rubber extension is how he did it I think, after removing the stocker FI pump).
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
