Need help fast! Oil Pan not coming off???
Old May 15, 2007 | 07:25 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have all the stuff removed that I need and I have jacked the engine up and the oil pan wont come off. I have it jacked up the point where the wheels were off the ground. the oil pan is hitting the flex pan. Need help quick.
Old May 15, 2007 | 08:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need help fast! Oil Pan not coming off???
Tried turning the crank to rotate the counterweights out of the way?
Old May 15, 2007 | 08:33 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
yep. The mark was pointing down and it didn't work and I have been doing 1/4 turns and it is still not coming off. I am about ready to explode. it is really pissing me off. If I can't get it soon. I am going to sell it. I am super frustrated. 4 days and I still haven't gotten the stupid oil pan off.
Old May 15, 2007 | 09:07 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
loosen the trans,take 2 long bolts put them where the bottom bolts went on trans,let it slide back on the 2 bolts ,pan comes off trans slides right back together,thats how i did mine hope this helps ,i know about the frustration,later jimmy
Old May 15, 2007 | 09:54 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Wheels off the ground. Did you take the blots out of the motor mounts so the motor would lift away from the frame.
Old May 16, 2007 | 12:38 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Also, make sure you take your distributor cap completly off, not just loosened. I had the same problem in my camaro when I was replacing the rear main oil seal. Took two days before my neighbor came over and pointed to my distrib and said it was hitting the firewall.
Old May 16, 2007 | 12:41 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I had a similar problem during my removal/installation
a few months back, where the edge of the oil pan was
tagging the flexplate.
Depending on how much room you have, use
some force, pull the back corner down, get one
corner to clear, then shimmy it out.. It took a
little muscle.
I had to use a rubber mallet and a friend to
pull a corner down while I was tapping, and it
came out with some finesse.
I had about a inch to work with, so I knew I
could get away with it, not bending or flexing
the pan in the process.
I found the trickiest part was sealing it back
up, as I had to shove the pan back in place
then, seal it with RTV underneath the motor.
If all else fails, try 1FastAm's idea or pull it..
Good luck
Old May 16, 2007 | 07:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Did you take off the converter/clutch inspection cover?
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
