ok what cumbo are u guys in the 13's running
Old Jun 9, 2007 | 11:12 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
my brother is working on a car 86 trans am now and is want to get it to 13's but not wanting spending to much money and so today he got a 350 long block to build so what is best way to go with it. it has 882 heads to i know there not the best but if he use dome piston will it make good power. or what heads under 1000 dollars would work
Old Jun 10, 2007 | 12:41 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: ok what cumbo are u guys in the 13's running
vortec heads and a decent cam will get you into 13s without the domed pistons
Old Jun 10, 2007 | 12:45 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
I've seen vortec heads with the right cam throw down 400rwhp, better be a hell of alot faster than 13s haha
Old Jun 10, 2007 | 09:21 AM
882 heads ... dome piston
World's worst combo. Don't even THINK about going there. People have been being disappointed by that combo since the 882 first appeared. I got to where I had to refuse to build it for people in the mid 70s, because I didn't want to deal with all the complaints and dissatisfaction any more.
What pistons are in it now?
Old Jun 10, 2007 | 10:56 AM
intex1982's Avatar
it has dish piston now. ok where can i get a set of vortec heads and how much and what cam good.
Old Jun 10, 2007 | 11:31 AM
Car: '72 Chevy Nova
Transmission: TH350
Summit sells assembled vortec heads (might want to check what springs are on them as they may need to be changed) for pretty damn cheap, iirc.
You'll need something like the edelbrock rpm airgap intake manifold for vortec heads, and a decent cam. Do you have a roller block? If so, the XR276HR (224/230 @ .50) or the XR282HR (230/236) will work nicely. I've seen the vortec heads/edelbrock rpm A/G with the XR282HR camshaft put down slightly over 400 rwhp and run 12s with ease. Proper supporting bolt-ons of course.
Old Jun 10, 2007 | 02:16 PM
intex1982's Avatar
the motor in the car now
Attached Thumbnails ok what cumbo are u guys in the 13's running-060707_19391.jpg
Old Jun 10, 2007 | 02:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so it has a single barrel carb?
Old Jun 10, 2007 | 02:58 PM
Car: '72 Chevy Nova
Transmission: TH350
wow replace that "thing" on top of your motor with a decent intake and a good carb and you'll probably see a metric ****-ton of improvement haha
Old Jun 10, 2007 | 03:06 PM
intex1982's Avatar
lol it only has a 267 in it. it has perfrom rpm with a 600 holley now. He only gave $350 for the car.
MustangBeater20
Oct 29, 2022 09:20 PM
86IROC112
Aug 17, 2015 02:00 PM
BBSDesigns
Aug 11, 2015 07:39 PM
squiggy2
Aug 9, 2015 09:30 PM
