Engine Mounts
Old Jul 5, 2007 | 05:06 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Engine Mounts
Just got done changing engine mounts and man was that tough. Two guys 4.5 hrs.
Auggie
Old Jul 5, 2007 | 05:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Mounts
You can do it yourself in about an hour if you only undo one bolt on each side.
Old Jul 5, 2007 | 05:15 PM
Auggie's Avatar
Re: Engine Mounts
Man, do I wish you were here when we did this. Did the drivers side first then the pass side.
Auggie
Old Jul 5, 2007 | 06:34 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: Engine Mounts
How do you remove an engine mount held by 3 bolts by just removing one?
It took me 6 Hours to do it by myself! I also did the trans mount, Oil, Oil filter and new spark plugs.
But 1 week later both mounts are broken! don't ask me how.
Old Jul 5, 2007 | 06:39 PM
Auggie's Avatar
Re: Engine Mounts
Yah, I would like to know too???
Auggie
Old Jul 5, 2007 | 06:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Engine Mounts
By not removing the mount.
Remove the lower nut and bolt on each side, drill or grind out the lower rivets, pry the mount apart just enough to slide the old mount out and replace it with a new poly mount, squeeze the mount back together and hold it in place with vice grips or C clamps or whatever works, drop the bolts in from above, use super glue to hold the nut in an open-ended wrench while you turn the bolt to get the threads started, torque to satisfaction, lower the car.
Old Jul 5, 2007 | 07:22 PM
Auggie's Avatar
Re: Engine Mounts
Hay, thats pretty good. Will that only work with the poly inserts??
Auggie
Old Jul 5, 2007 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Engine Mounts
It will only work with some sort of insert. If you're using a stock rubber mount that comes already enclosed in the metal shell, you'd have to take all 3 bolts out.
Old Jul 5, 2007 | 07:37 PM
Auggie's Avatar
Re: Engine Mounts
Yah, thats what I thought. Thank you.
Auggie
Old Jul 5, 2007 | 09:07 PM
VenomX-87's Avatar
Re: Engine Mounts
Arnt the rubber mounts ment to be fixed to the metal housing because my stock replacements the rubber has come loose and the engine is now on a slope.
Old Jul 5, 2007 | 11:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Engine Mounts
They're not fixed, they're just squeezed between the two metal halves.
Old Jul 6, 2007 | 02:23 AM
VenomX-87's Avatar
Re: Engine Mounts
soo if my RHS (aussie drivers side) is sitting low in the mount and the LHS is sitting higher in the mount it is normal?
Sorry about the quality, camera phones + dark don't mix well, But here are the 2 mounts:
RHS: http://i21.photobucket.com/albums/b2...nginemount.jpg
LHS: http://i21.photobucket.com/albums/b2...nginemount.jpg
Old Jul 6, 2007 | 11:07 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Engine Mounts
Have you got the clamshells bolted to the engine on the right sides?
Old Jul 6, 2007 | 07:54 PM
VenomX-87's Avatar
Re: Engine Mounts
I never changed them (it was like that when i got it) i just swaped new mounts in. Why do they look wrong?
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
