new cumbo for brother any ideas on power
Old Jul 7, 2007 | 12:01 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Its in the works 350 bored 30 over with 10.5 cr, 416 heads, perform rpm intake, 600 holley vac. sec. this cam .454 .454 lift http://www.cranecams.com/?show=brows...52&lvl=2&prt=5 any ideas on what power it will make?
Old Jul 7, 2007 | 12:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: new cumbo for brother any ideas on power
i am gonna bet 300-320 hp
Old Jul 7, 2007 | 12:39 PM
intex1982's Avatar
with stock 416 heads?
Old Jul 7, 2007 | 12:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea. The 216/216 cam isn't very aggressive, especially with 10.5:1 CR, you could go bigger on the cam. I'd double check that CR, it seems rather high.
Did you port the 416s? They really wake up after that.
Old Jul 7, 2007 | 12:53 PM
Car: 91 RS
Engine: 350 vortec
well yeah 300-320.. not at the wheels but flywheel
Old Jul 7, 2007 | 01:23 PM
intex1982's Avatar
well 10.45 cr . one more problem it has a stock stall and 700r4 and 2.73 so he wants the power band low in the rpm. so what u think about this set up and it will have ac to?
how u port them. i have three set
Old Jul 7, 2007 | 02:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Pick up a book, read a few threads on here, go to work porting them.
Pick a smaller cam if you want more torque, and don't want to change out the stall speed. I'd say he should up the gear set no matter what though.
Old Jul 7, 2007 | 02:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
get a stock 4.3L 2wd S10 stall from a 1998 pickup and use that, it'll stall at 2200 or so and help out the combo, though those gears will kill it as well. I'd say 260hp at most out of that combo.
Old Jul 7, 2007 | 07:09 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
http://store.summitracing.com/partde...2&autoview=sku
a better cam with more low end. switch to a 3.73 more fun.
port the 416 heads using 1.94x 1.60" valves. 330 340hp
jaridjohn
Jul 8, 2024 03:49 PM
mdtoren
Aug 23, 2015 12:52 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
mdtoren
Aug 16, 2015 05:45 PM
stalkier
Aug 13, 2015 12:59 PM
