Fuel pressure problem
Old Jul 10, 2007 | 06:18 PM
TAtothefloor's Avatar
first a little backround i have a 89 gta with a rebuilt tpi 350 that i just fired up a week ago i can get it to run but only while i hold the gas and i have checked everything else and i know its fuel
ive been reading posts tryng to figure this out
1st problem-
recently when i turn the key the pump will not prime i checked all the fuses in the block good fuse by the battery and a new fuel pump relay all the wires are connected no cut wires. the connector for the relay is greasy and dirty but would that be my problem? also i do not have the oil sensor hooked up yet and will do that tomorrow could that be the or a problem? i know its only a back up (so ive heard) any ideas?
2nd problem-
since the pump will not prime i have bypassed they relay and i can get it to work i can get fuel press when the pump is on but i drops immediately to 0 when i stop the pump I have brand new injectors and a new adjustable fuel reg and new fuel filter with half a tank of fresh gas. So i hope its not the injectors or fuel press reg could the o ring seal cause them to leak between injector and manifold? i will try the trick of squeezing off fuel lines to see if injectors or fuel press reg leaks or if the pump check valve is bad. If the check valve is bad isthere any other way of fixing it besides dropping the tank? also can i take the fuel rail out of the manifold with the injecotr still hooked up and test them?(i know it will shoot gas everywhere if theres a leak)
https://www.thirdgen.org/forums/tpi/...way-check.html
thats the post i read on checking injecotrs and check valve
any suggestions tips or advice will help im only 17 and dont have as much experience as you other guys
thanks in advance
brendon
Old Jul 10, 2007 | 06:21 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Fuel pressure problem
You must have an oil pressure switch...
The fuel pump primes so that you can have a quick start. After your engine is running (or just turning over with the starter enough to provide oil pressure) that switch is what turns the relay on and keeps it on as long as the engine is running. If you have jumped the relay and your engine runs then you have just proved that the oil pressure switch is needed.
Old Jul 10, 2007 | 06:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the ECM powers the fuel pump through the fuel pump relay as long as there are reference pulses from the ignition module. The oil pressure switch is just a backup.
Old Jul 10, 2007 | 07:28 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Doesn't it work that if the oil pressure is less than 7psi the pump won't run, and i believe if you have the sender unhooked it reads as 0psi?
Old Jul 10, 2007 | 07:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it doesn't.
Old Jul 10, 2007 | 07:35 PM
is that just on TPI or on TBI also, on my LO3 car I'm running a points distributor and the fuel pump runs whenever the car is running.
Old Jul 10, 2007 | 07:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Its true on both TBI and TPI.
On your car the fuel pressure switch will be keeping the fuel pump running, since the ECM won't be happy.
KrisW's Avatar
Engine: 2.8/TBI/TPI
My 90 V6 car ran two weeks with the oil switch jumpered while I farted around and waited to replace my oil switch.
It would not run with the oil sender unplugged...
Old Jul 10, 2007 | 07:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You had other problems, then.
Old Jul 10, 2007 | 07:58 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Just when I thought things were fixed!!!
Oh well, that engine went into an S10 a long time ago... and that was 4 firebirds ago!
More knowledge is better; thanks for the tip!!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
