what problems from a 9 year old ZZ4?
Old Jul 27, 2007 | 04:37 PM
89IROCZZ4's Avatar
I am looking to get a Camaro with about 25-30k miles on it. The past few years, it has mainly just sat. It was installed back in '99. Are there any potential problems that I should look for in a motor that is about 8-9 years old, with a supercharger on it? Or should it be able the same as an engine that has been run for 3 years with 25-30k on it?
Old Aug 6, 2007 | 11:26 PM
89IROCZZ4's Avatar
Re: what problems from a 9 year old ZZ4?
ttttt
Old Aug 6, 2007 | 11:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hypereutectic pistons, supercharger, has sat mostly for a few years. . .
Sounds like a high likelihood rebuild candidate.
Old Aug 6, 2007 | 11:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Engine parts will rust and sieze up when they're just sitting like that with no oil. If he rotated the engine either with a wrench or by starting it every so often, it should be good. Hopefully the oil was changed during the time it sat. If not, you're taking a big chance on getting a junk engine.
Old Aug 6, 2007 | 11:48 PM
89IROCZZ4's Avatar
will they be able to catch things like this if I take it to a shop before purchasing to have it checked out? If so, what all should I have them do?
Old Aug 6, 2007 | 11:54 PM
five7kid's Avatar
Maybe. A compression check would be one possibility.
Oh, is this in the humid Houston area?
Old Aug 6, 2007 | 11:57 PM
89IROCZZ4's Avatar
the humid houston area ... as opposed to the dry houston area? Yes, it is in h-town. I want to do everything possible to make sure this car is fine.
Old Aug 7, 2007 | 12:14 AM
89IROCZZ4's Avatar
also, what is the longest amount of time a car would be fine while sitting? I wouldn't imagine it would have gone more than a few months without being started up but then again I don't know.
Old Aug 7, 2007 | 11:48 AM
five7kid's Avatar
If not prepped for storage, especially in a humid area, cylinder corrosion can occur pretty rapidly.
Was it stored inside, or outside?
Ghettobird52
Jul 5, 2024 11:18 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
