Probly a noob question.
Old Aug 10, 2007 | 04:21 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
Hi all, im new to the forums here and am learning about cars. I have an 84 camaro with a 305 engine that recently died on me. I am considering getting a 350 from a chop shop and i was wondering if the 350 would bolt up onto the the tranny i have in my car already? It's an automatic.
Old Aug 10, 2007 | 04:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Probly a noob question.
Yes, the 305 and 350 are externally identical.
Old Aug 10, 2007 | 04:41 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
alright cool, 2 more noob questions i gotta ask, are the motormounts the same? and my 305 right now is carbuerated, would i be able to put a fuel injected 350, or woud i have to stick with a carb engine?
Old Aug 10, 2007 | 05:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Everything is the same.
You could put a fuel injection system on top of it, if you were willing to do all the work that would entail.
Old Aug 10, 2007 | 05:02 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
First off, what do you mean your engine died? What is the diagnosis and from whom? Switching engines and fuel systems may raise emissions/smog check issues depending on where you live.
Old Aug 10, 2007 | 05:04 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
well i was driving, heard a big bang from about under my seat where i was sitting, im pretty sure it was just a backfire, but anyway the engine shut off and i pretty much just rolled to a stop. i was thinking about fixing the engine but it has a lil over 300,000kms on it now and im a bit weary of that.
Old Aug 12, 2007 | 03:29 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Moonlight, that happened to me, it turned out my distributor froze up on me. Never saw anything like it before,it just froze up, loud explosion, I put it in nuetral and coasted to a stop. If you have not done so, you may want to check it out. If that`s the problem, it`s a cheap fix and may keep you on the road a little longer.
Old Aug 12, 2007 | 03:36 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
Yea thats definatly a possibility, right now i just went to a few autowreckers for a 305 and the ppl kinda giggled at me. and to get a 350 engine with 108,000 kms would be roughly $1100, and got a ballpark of $400 to get it swapped in at a shop. Then i was thinking of slowly rebuilding my 305 or getting it rebuilt at a shop and sell it after.
Old Aug 12, 2007 | 03:44 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Moonlight, for $1100 you should be in the ballpark for a rebuilt longblock, either 305 or 350. Do you need your car now for transportation or do you have wheels when you need them? If you are not in a hurry, there are options which could save you money.
Old Aug 12, 2007 | 03:46 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
I actually am in a bit of a hurry so i get to work with it.
Old Aug 12, 2007 | 04:07 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
If you are in a hurry, a rebuilt long block may be the way to go unless you have a good machine shop in your area. The distributor that froze-up on me was on a new 350 long block I put in my `68 El Camino. I reused all the old bolt-on parts and before long the starter went bad along with the alternator, water pump, regulator, carb., everything that bolts on to the engine. It got to be a real pain to deal with. If you are on a tight budget, check your used parts carefully and replace as needed. It will help if you get things done correctly if you have a good shop manual and wiring diagrams. You never said whether or not you have to smog your car.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
