Visual Difference (between 305 and 350)
Old Aug 20, 2007 | 07:44 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
I was just wondering if there was any visual difference between a 305 and a 350 engine or do they basicly look identicle?
Old Aug 20, 2007 | 07:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Visual Difference (between 305 and 350)
the only real ways to tell is possibly the casting number, or pull a head off.
is this motor in a car? the vin will tell you what it SHOULD be
Old Aug 20, 2007 | 08:13 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Yeah besides looking up the casting number or the VIN number, there is really no way of telling. The engines are identicle.
Old Aug 21, 2007 | 09:39 PM
djtricia's Avatar
Car: 1986 Z-28
On the back of the engine just above where the tran bolts on will be a number cast in teh block. 5.0 is 305, 5.7 is 350. This is only on the newer engines I believe.
Old Aug 25, 2007 | 05:55 PM
third gen crazy's Avatar
i have also heard that the harmonic balancer's are different sizes
Old Aug 25, 2007 | 06:10 PM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
From the factory perhaps, yes. But neither that nor the VIN is a reliable way to know unless you're 100% sure the engine has never been swapped. And if you knew that, you wouldn't be trying to find the displacement now... Look above the transmission bolts, cast on the back of the block on the driver's side.
If it's too hard to read the casting number, I believe someone on here once said you can park the car sideways on a 45 degree incline, then rotate the crankshaft until one of the pistons is at the absolute bottom of its stroke. Pull a sparkplug and fill that cylinder with oil. Measure the amount of oil. Multiply by 8.
Old Aug 25, 2007 | 08:41 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by facelessnumber
...If it's too hard to read the casting number, I believe someone on here once said you can park the car sideways on a 45 degree incline, then rotate the crankshaft until one of the pistons is at the absolute bottom of its stroke. Pull a sparkplug and fill that cylinder with oil. Measure the amount of oil. Multiply by 8.
Thats ok, I think I could get motivated to read the casting number...
Old Aug 25, 2007 | 09:35 PM
Car: 91 RS
Engine: L03 carbed
Kinda my point. You gotta read that casting number.
Of course, there's a remote chance somebody changed the crank. You could be looking at a 327 stamped "5.7." (Or a 383 for that matter...)
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
