cruise control quit working help
the cruise control in my 87 gta suddenly quit working it was working then i parked the car and got in it about an hour later and no cruise i checked the vacume hoses no leaks its got to be something electrical, and i don't have any codes so i don't think it is the speed sensor help!!!!!!!!
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: cruise control quit working help
There are there coils inside of the servo. Two control the vacuum, and one physically PULLS the servo. Open up the back cover, fine the appropriat leads , and ohm them out to make sure there is no break in the coil. Also, remove and oil the vacuum valves and o rings.
PS.
With the car running, you should be able to use a 12 volt battery or car charger to activate the coils and make sure the servo works. You need the car running so that there is a supply of vacuum.
PS.
It's worth a check. AFAIK the control box is solid state.... I would focus on the pieces with moving parts first.
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Did you check the vacuum switch on the brake/clutch pedal? If it is cracked so the vacuum vents it will disable the curise. Opening the vacuum switch tells the curise control that you are braking and/or pushing in the clutch which disables the cruise control.
Dave
Dave
yea i believe i ve narrowed it down to the switch but i just want to thank everone for their input im gonna try the tech artical on how to bypass the oe switch and make your own using two momintary switches and a toggle switch thanks again
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Yea it was the switch on the column i just made my own switch with the instructions i found here on the forums and mounted it on the dash and its been working for a while now ill see if i can get some pictures up
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
