diesel sounding...
Old Sep 12, 2007 | 09:16 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
diesel sounding...
I replaced my intake manifold,now it sounds like a disel and missfires..... gonna check it out when i get home, but what is the sound from, how would this be fixed any idea's ?
Old Sep 12, 2007 | 11:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: diesel sounding...
Problems with your timing or your firing order.
Old Sep 12, 2007 | 12:10 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
ok, ill check that, it does the sound really loud at anything above 1000 rpms, seems to have power loss, and it definantly is misfiring :/ How would i adjust my timing on a stock 305 tbi ?
Old Sep 12, 2007 | 12:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
With a timing light, pretty much like you would on anything else.
Old Sep 12, 2007 | 12:39 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
ok i got a timing light whut do i do to the distrib?? its got 2 screws in it to keep it from moving..
Old Sep 12, 2007 | 12:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There should only be one bolt holding the distributor clamp down. Loosen it slightly until you can rotate the distributor body, then adjust it as necessary until the timing marks align when you look at them with the light.
Old Sep 12, 2007 | 12:49 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
First, I would make sure you didn't put your distributor in 180* backwards. Make sure all your plug wires are connected both at the plug and at the distributor. Tight connections from the harness to the distributor in back should be checked too. Fuel injector connections too.
To check your timing, unbolt the distrib hold down bolt and unplug the EST. Turn the car on and check timing. Turn the distributor counter clockwise to advance and clockwise to retard. Keep doing that until you get between 6-8 degrees base timing and lock it down. You may wanna reset the IAC and tweek the TPS too.
Old Sep 12, 2007 | 12:54 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
i tired putting the dis in the way it was when i took it out but it would only go in one way, or is there a 180degree spot to?? 2 to spots i can put the dis in ??? so it will seat properly! Thanks AP for your help!! I learned how to adjust timing today woot!! is it hard to twist that body then tighten that bolt back down, i had to use a box wrench to get to that bolt kinda hard to hold the distrib and tighten it ^^
Old Sep 12, 2007 | 01:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you didn't disturb the position of the distributor rotor or the crankshaft while the distributor was out, then putting it back in the same position is fine.
You can get a distributor wrench at any parts store to make turning the hold-down bolt easier.
Old Sep 12, 2007 | 01:32 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
ok, i didnt move the crank, cam anything lol, the metal plank on the distrib was facing the alternator, when i put it back in it was like facing the radiator so seemed a lil bit off.... is that normal, i tired putting it in like 4 different ways and it would only seat in one way!
Old Sep 12, 2007 | 01:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The distributor rotor has to be pointing in the same direction as it was before you pulled it out.
Old Sep 12, 2007 | 01:39 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
hmm so i gotta figure out how to "say if ur looking at ur engine from the front of the car" make it point to 4 instead of 6.........
Old Sep 12, 2007 | 03:02 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
It sounds like you are a cylinder ahead of where you should be. Most definately, the rotor has to be in the exact spot where you left it. Marks on green tape or the firewall or some thing should have been done to note your location.
When you were reinstalling your distrib, you probably were bumping into the oil pump shaft making you think it was not aligned properly. You should have "retarded" the rotor a bit so that when you slid it on, it would rotate clockwise and fall into the exact position. You'll remember the gear on the end of the shaft was curved (for lack of a better word), that means it will not slide directly on, it kind of had to be rotated back into place. Think back to when you took it off, do you remember while you were pulling it out, that the rotor may have moved in one direction? You needed to duplicate that, only in reverse.
Now you need to get the engine set to TDC on the #1 cylinder and start over. I have never had to do that so I cannot tell you how it's done. As much as I hate it when people tell me to do this, you should search and you'll find the correct procedure for realigning everything.
Old Sep 13, 2007 | 09:14 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Yea it was the timing but i didnt fix it , had to have a shop do it cuz, while i was driving my lugs poped off and so did my tired i got a whole new mess to work with now gonna be like 600$ to fix the left side in the tirewell, then i gotta add a new panel cuz the tire came back and just destroyed my pretty paint job L
thanks for yall's help glad to see whut you were saying is what was wrong at it gives faith in the forums hehe
school boy
Oct 22, 2015 11:47 AM
MSRed91Camaro
Oct 6, 2015 01:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
davecamaro
Apr 18, 2002 09:46 AM
White Ninja
Feb 10, 2002 12:36 AM
