Ticking Noise... strange how it happened
Old Sep 17, 2007 | 01:07 PM
92transam5.7ws6's Avatar
I was driving my 92 T/A in some heavy rain going 30mph when i drove into a deep water puddle. The car almost came to a complete stop immeadiatly as well as the motor nearly dying. I got the RPMs back up with a little TLC and figured the large amount of water choked out my car.... no biggy right? Well about two blocks later, with no change in performance, I pull into a parking lot and here was sounds like a lifter knock. I've pulled the valve covers and none of the rocker arms are going crazy. Should every single rocker be shooting out oil or only when they're engaging? This is a car that hasn't broke a single thing in 5 years and she's been taken out by a puddle!!! I have a moderate knowlege of engines but i'm outta my league...
Old Sep 17, 2007 | 01:18 PM
rhamm1320's Avatar
Re: Ticking Noise... strange how it happened
Does it feel like its down on power or missing? Also, is the sound at idle or does it go away when the rpm comes up? I agree, strange, hopefully is something simple or something that goes away on its own.
Old Sep 17, 2007 | 01:26 PM
the speed of the ticking DOES increase with RPM. There is no apparent decrease in power
Old Sep 17, 2007 | 01:30 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Uh oh, I hope you didn't hydro-lock it...
Does it sound like this?
http://www.youtube.com/watch?v=DfJIpiQZtR4
Or this?
http://www.youtube.com/watch?v=pvm-tfF9Nd4
Theyre both rod knock.
Old Sep 17, 2007 | 01:35 PM
Or this?
hydro-lock? I've never heard that term in my life... ?
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I know a guy that hydro-locked one - bent a connecting rod. However, he had a cylinder fill with water while the engine was off, and the damage happened at startup. The only reason he knew something happened was a light ticking noise. If yours was running the whole time it doesn't seem as likely.
Car: 1992 Camaro RS
http://en.wikipedia.org/wiki/Hydrolock
Old Sep 17, 2007 | 01:42 PM
its more of a ticking but it definatly does sound like a rod to me. I will set up a link on youtube as soon as I can
Old Sep 17, 2007 | 01:45 PM
Car: 1992 Camaro RS
It's not the first time, a local guy here fell victim to the exact same thing.
If it's a rod that's making the noise, you're gonna have to tear the whole motor down. Might as well do a full rebuild, upgrades if you can afford it.
Old Sep 17, 2007 | 02:36 PM
what if it died for a brief second... would that be enough? and if so how could i tell that thats the problem? And if there was gas in the motor, wouldnt it just burn it off?
Old Sep 17, 2007 | 04:00 PM
rhamm1320's Avatar
I have never experienced it myself, but heard about it before. Do you think you could have digested any significant volumn of water? Hope not, good luck getting it firgured out and hope you get it worked out soon.
Old Sep 17, 2007 | 04:39 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
One of the reasons I don't drive through puddles of water. You don't know how deep the water is. In fact i try not to even drive in the rain, especially heavy rain. Our cars don't like bad weather.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
