rearmain seal leak?
Old Oct 3, 2007 | 12:07 PM
84noname's Avatar
rearmain seal leak?
im leaking between the tranny and motor, havent had a super good look. i know the car goes thru oil, always has.original owner told me it was just valve cover gaskets. i leak puddles the size of pancakes when i stop for gas. also one time i was getting on it and i saw something spray from out from underneath my car while doing about 60mph. im losing alot of oil.
any suggestion on what i should do
Old Oct 3, 2007 | 06:05 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: rearmain seal leak?
Originally Posted by 84noname
... i leak puddles the size of pancakes when i stop for gas. also one time i was getting on it and i saw something spray from out from underneath my car while doing about 60mph. im losing alot of oil.
Wow. Leaking that much will be easy to find. Everything you describe could be caused by valve cover gaskets. Especially the cloud behind you when you go up a hill at WOT.
Valve cover gaskets are not that hard to do, and not that expensive.
Change them or get them changed to take them out of the equation then see what you have left.
Old Oct 3, 2007 | 06:32 PM
84noname's Avatar
yeah i was planning on it in a few days, i have all the time in the world but no job, so cash is an issue. funny how when u have a job theres money to do stuff but no time, and when u have no job u have time but no money
intake looks nasty too. the front, so im sure the back strip isnt much better
Old Oct 3, 2007 | 06:35 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Second on the valve cover gaskets, and check for the 'sofakingdom' leak.
Old Oct 3, 2007 | 06:54 PM
84noname's Avatar
the what??? i saw that word on someones screen name, whats it mean? messed up?
Old Oct 3, 2007 | 06:58 PM
naf's Avatar
naf
No NOT messed up. It's the leak from the front of the block when the smog pump is removed and a short bolt is not installed into the mount hole that penetrates into the fuel pump pushrod bore.
Old Oct 3, 2007 | 07:12 PM
Engine: 350 4BBL
How to tell if you spend too much time on TGO?
...you know exactly what the "sofakingdom" leak is.
Old Oct 4, 2007 | 02:27 PM
84noname's Avatar
wow,lol,well now i know, so while we are at it i want to remove my smog stuff, good or bad? how do i plug up everything, i already took the belt off. engine bay would look nicer with it gone for sure no emission for me so not a big deal
Old Oct 4, 2007 | 09:27 PM
Engine: 350 4BBL
It depends on what year it is and if it is TPI. Do a for "smog delete". Should be plenty of threads to read...
Old Oct 5, 2007 | 03:40 AM
84noname's Avatar
oh yeah tons
Bubbajones_ya
Jul 6, 2024 08:32 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
