Car wont start
Old Oct 19, 2007 | 12:53 PM
RobbyKlotz's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Transmission: Stock 5 Speed
Axle/Gears: Stock
Car wont start
A little bit of a backgroud. Car is a 91 Camaro RS 5.0 TBI.
The car ran fine, and parked it for the weekend. Went to start it a few days ago, nothing... Just a clicking sound every time i turn the key coming from under the dash on the drivers side.
I am starting to think starter relay since that the clicking sound is coming from that general area...
Thoughts?
Old Oct 19, 2007 | 12:58 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Car wont start
Sounds like your battery is dead. Something may have drained while it sat over the weekend. Try jump starting it
Old Oct 19, 2007 | 01:04 PM
RobbyKlotz's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: Stock
Re: Car wont start
Yeah we tried jumping it, still same thing. Just a clicking under the dash... Not sure where to go from here...
Old Oct 19, 2007 | 01:14 PM
bigj350's Avatar
Re: Car wont start
Try a different battery, the old might be bad and unable to take a charge
Old Oct 19, 2007 | 03:28 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: Car wont start
I once had an RS that did the same thing...turned out to be a fusible link up by the battery somewhere. (if I remember correctly)
Old Oct 21, 2007 | 05:25 PM
RobbyKlotz's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: Stock
Re: Car wont start
We tried a brand new battery with same outcome. Just even attempt to turn over, just a weird clicking sound under the dash.
Will check the fuse able link on the starter, another other thoughts tho?
Old Oct 21, 2007 | 07:39 PM
bigj350's Avatar
Re: Car wont start
Take the starter into autozone and have them test it.
Old Oct 21, 2007 | 11:50 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
Re: Car wont start
Have someone hold the ignition to the start position while you check voltage at the solenoid. if there's voltage there, your problem is the starter.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
