found a few problems need help
Old Oct 22, 2007 | 08:54 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
There is a line coming off my intake going to some canister looking thing well the line seemed to melt into the back of my alternator what symptoms would this cause? the second is a have a burnt and melted connection dont know what its to? there are pics inside the thread
Sorry about the double post didnt know where to put it?
https://www.thirdgen.org/forums/nort...blems-but.html
Old Oct 22, 2007 | 09:25 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Re: found a few problems need help
I replied on the other forum, but you're more likely to get answers here, so I'll put my replies here from now on.
Old Oct 22, 2007 | 11:07 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
thanks sorry bout the post in other forum im a noob
Old Oct 22, 2007 | 11:14 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
how do you fix vaccum hose i tried to pull off the alternator and it cracked in half so.. i need to replace the whole thing any ideas
Old Oct 22, 2007 | 11:19 PM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Engine: 40 over TPI 305
Axle/Gears: 3:73
I've taken those things out of every car I've ever owned that still had one. But if you must have the charcol cannister, just pull the line off and run a new one.
Old Oct 22, 2007 | 11:25 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
whats a charcol canister?? so its not going to make a differnece? it was hooked into my intake so i thought i needed it
Old Oct 22, 2007 | 11:31 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
from my limited understanding the coal canister (the black can) does a few things. I am only sure of one. Extra fuel vapor that is not burned off goes into the canister. It then goes from vapor to liquid state and goes back to the fuel tank. You loose it you have to put the line (the broken one when replaced) and connect it to the line that goes to the tank. Only thing is it's still a vapor and it can sit there and not go to the tank.
I took mine off my 84 El Camino b/c i was exempt from any emissions and it was in the way. My 91 is fuel injected and the computer controls the purge (or release of the fuel) from the tank. I don't want a SES light or anything to throw it off. I'd keep it. You don't gain anything but actually loose, in my opinion.
Old Oct 22, 2007 | 11:43 PM
1bad86z28's Avatar
Car: 86 I.R.O.C.
Axle/Gears: 3:73
If you want to keep it, just run a new vaccum hose, it's like .25cent a foot.
Old Oct 22, 2007 | 11:53 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
thanks i live in ca so i have horrible smog laws so im sure i need it
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bert87
Aug 23, 2015 03:50 PM
bjpotter
Aug 12, 2015 06:06 PM
Fronzizzle
Aug 9, 2015 01:15 PM
antares57
Aug 6, 2015 07:47 AM
