383 cam
Old Nov 5, 2007 | 12:11 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
383 cam
any suggestions? swirl port heads, 2.02 , 1.60's
i want a mild sounding engine, easy to tune with MAP
Old Nov 5, 2007 | 12:53 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 383 cam
You might want to give some details about the engine you are going to use before asking for general advice.
Ex: Is it a roller-block? Using factory TPI? Aftermarket TPI? HSR? Staying with the 5-speed? Factory exhaust?
Cam selection is important and there are a lot of variables that go into choosing a good one for a given application.
Also, you should do a search... 383 cams have been talked about a lot on here.
Last edited by formula_novice; Nov 5, 2007 at 12:54 PM. Reason: Automerged Doublepost
Old Nov 5, 2007 | 01:19 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
Re: 383 cam
you didnt give that much info but a nice mild cam would be the performer rpm cam from edlebrock but a cheaper version and a bit more efficient would be the summit k-1107
ps i said that cam assuming your preety much building a basic small block
but like i said before you didnt give that much info im sure we could all give you a better idea of a cam but .. no info
Old Nov 5, 2007 | 01:40 PM
Car: 91 formula ws6
Re: 383 cam
stock t.p.i for the time being, (till hsr)
exhaust will support 500 horses
stock swirlys with 2.02 1 60s, the rest is standard
Old Nov 5, 2007 | 02:03 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: 383 cam
Best way,
Call cam maker of your choice, I've used Comp for many
years.Tell him what you have and intended use, don't
fudge on intended use.
They have a pretty large data base on what works in
specific applications.
TPI and HSR two different cam selections.
I'd wait till you go HSR and then cam for that
One cam combo cheaper than two
JMHO
Later
Old Nov 5, 2007 | 02:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 383 cam
Stock swirl ports on a 383?? That's a waste of a head gasket there
Upgrading to HSR and doing heads at that time?
More importantly, your CR is ok with swirl port heads and the long stroke?
Old Nov 5, 2007 | 04:53 PM
Car: 91 formula ws6
Re: 383 cam
ya, 9.5 CR
swirls will be ported, and im putting edelbroks on l8r
i just want something that me ( a newbie) can tune and still chirp 3rd gear nice
roller cam
Old Nov 6, 2007 | 09:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 383 cam
Comp XFI268HR-113. One of the best roller cams for TPI, period. Not sure if it will work with a stock MAP chip, but should be very easy to tune with a custom chip.
Old Nov 7, 2007 | 01:55 PM
Car: 91 formula ws6
Re: 383 cam
thank you, thats all i really wanted to hear,,,
otherwise, anyone recomend the zz4
or keeping stock lifters?
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
