Harmonic Tool stuck in crank.
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
I tried using a bolt with a lot of red thread locker to get it out and that didn’t work. The thing that is stuck in the crank is the adapter for the tool's bolt to install the Harmonic Balancer. Of course the adapter has nothing I can get a hold of... So I need some thinking help, Please help me I want to get this thing out of it with out going to a machine shop.
Edit: Would it hurt anything just to leave the adapter in their and put a bolt that fits in the adapter and use that bolt as the center bolt for the crank pulley?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Harmonic Tool stuck in crank.
picture??? i have no idea what you are tryin to say
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The threads are probably screwed in the end of the crank now. I never use the tapered adapter in the hole when pulling a balancer. You should have taken the balancer bolt and washer off, removed the washer then reinstalled the bolt. Use the flat adapter from the puller and push against the head of the bolt.
Same goes for installing the balancer. You never use a bolt to pull the balancer on. You'll pull the threads out of the crank. A threaded rod is screwed into the crank then a nut and a couple of washers are used to force the balancer onto the crank. That way the rod never turns in the threads of the crank.
I have no idea how you'll get the adapter out of the crank without damaging the crank.
edit: I know what you're talking about now. You tried one of those universal adapter installers with different adapters for different cranks. You'll probably screw it up but try using an easy-out or screw extractor.
Car: 89 GTA
Engine: L98 350
First picture shows the adapter in the crank. The seconded picture shows the other adapters in the box, one is missing because it’s stuck in the crank.
Car: 89 GTA
Engine: L98 350
If I use an easy-out is it possable to screw up the adapter with out getting it out? If that could happen knowing my luck it would. Could I leave the adapter in the crank and use a differnt bolt for the center bolt?
Car: 87 IROC L98
Thread a nut onto the bolt then thread the bolt into the adapter. Tighten the nut to the adapter and see if the bolt will take it out then.
You could always put a bolt into the adapter as I previously mentioned and pull the balancer back off. Then use some vise grips on the adapter.
Car: 89 GTA
Engine: L98 350
I don’t have the tool to pull it back off and the out side part of the adapter is really smooth and I doubt I can get a vice grip to hold on to it that tight.
However the bolt with a nut idea is a really good idea I have used that before on something else and it worked I should have thought of that before bugging you guys. But it doesn’t seem to be working this time, no matter how hard I tighten it. So I put some more thread locker on it got it real tight with one guy holding the ratchet and me tightening the nut with a wrench. Hopefully it will come off tomorrow when I try again. But at least now I have a bolt I can turn over the engine with while I finish it up.
Car: 89 GTA
Engine: L98 350
1fastam suggested I used a welder, and weld the nut to the adapter. I don’t have a welder but it gave me another idea, to use JB weld I don’t know how strong this stuff gets especially sense it is not how its supposed to be used. anyways I’m posting this up to see if this would be a good idea or a bad idea.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Go buy a harmonic balancer remover tool. Take the balancer off.
Use a big pipe wrench to remove the adapter.
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
The pipe wrench is a great idea. do what he said.
Car: 89 GTA
Engine: L98 350
Easy-out worked. i'm debating on returning it or not... that adapter is ruined.
I'm a fan of easy-outs now.
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Same thing just happened to me today. I'm getting an easy-out tomorrow.
Engine: LB9 305
Transmission: AT
Old thread...
I've had this happen before too; a long long time ago in a galaxy far far away. A horrible learning experience back on one of my first cars, during the Civil War or thereabouts. That adapter thing is just the right size to go partway down into the sort of funnel-shaped end that most SBC cranks have. Then either it jams itself in there whole, or the press screw breaks through the end of it and the remains get stuck.
I just put a bolt in the crank... doesn't have to actually screw in, a flex plate bolt is about perfect, just kinda slides in and the head gives something flat and solid for the screw to press on without adding very much length to the crank.
I tried using a bolt with a lot of red thread locker to get it out and that didn’t work. The thing that is stuck in the crank is the adapter for the tool's bolt to install the Harmonic Balancer. Of course the adapter has nothing I can get a hold of... So I need some thinking help, Please help me I want to get this thing out of it with out going to a machine shop.Edit: Would it hurt anything just to leave the adapter in their and put a bolt that fits in the adapter and use that bolt as the center bolt for the crank pulley?
