Great, now my car is possesed
Old Nov 24, 2007 | 12:48 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I was going down the freeway the other day driving back from phoenix and i was cruisin at about 70, not really passin anyone or anyhting then all of a sudden my gas pedal just up and pushed it self to the floor! Without my foot! and i thought i was goin crazy, so i didn't pay any attention to it, like 5 minutes later i took the south exit on the loop 202, which is a nasty off ramp cuz it does like a complete circle, so i slow down to go into it then the car does it again and i almost smacked the damn wall! I need to know what this could be before i die lol I thought of the throttle cable being stuck up but that wouldnt jerk on it, is there somthing wrong with my throttle body internally?
Old Nov 24, 2007 | 01:32 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Great, now my car is possesed
There could be something wrong with the throttle body, but to pull the pedal to the floor is the weird part...you got cruise control by any chance?
Old Nov 24, 2007 | 03:33 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
TThe cruise control could be shorting out. It is usually a PWM signal that sends vacuum to a servo. If it is shorting to a power source it could be engaging the servo at full...
Old Nov 24, 2007 | 03:50 PM
84redta's Avatar
that is what i thought, i remember BMW was having this problem for the longest time with a couple crashes to boot...thats where i was going...
Old Nov 24, 2007 | 06:23 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
no which is the part that confused me, i have no CC on it at all
Old Nov 24, 2007 | 09:34 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
have you found an exorsist yet?
Old Nov 24, 2007 | 10:21 PM
84redta's Avatar
could the computer be going wacko. I know when it needs to heat up it keeps it open a lil more to get more air...could the computer be throwing it open?!
Old Nov 25, 2007 | 03:23 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
computer doesnt touch the gas pedal so that makes no sense to me. you got one weird problem there maybe it is a faulty t/b?
Old Nov 25, 2007 | 03:27 PM
84redta's Avatar
didn't think so...these cars have a gas pedal return spring!? haven't been down there in a while...but that makes no sense that it's outta no where that it would drop...master_disaster...check your RPOs...see if you HAD cruise control and someone didn't just switch out the turn signal lever...
Old Nov 26, 2007 | 06:30 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yeah im gonna run my vin thru alldata at school and have my teacher help me with it
Old Nov 26, 2007 | 06:46 PM
84redta's Avatar
yea your vin isn't going to tell you what you had for options other than engine and model and production plant, you'll need to look at your "Service Parts Identification" sticker to check your RPO codes, should be in your center console, there is an easy software download off the HOME page that will identify what options you have. If the sticker is pealed off by the previous owner like 80% of our cars were...good luck finding out what you got...i'm still trying to figure out my car.
Old Nov 26, 2007 | 07:28 PM
Toehead's Avatar
Just look fo the cruise control servo! There should only be one throttle cable connected if you had no cruise. (not to be confused with the tv cable for an auto)
Old Nov 26, 2007 | 07:35 PM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Check for a broke motor mount, Allowing engine to rock up causing throttle to stick. Dave
specialized
Jun 18, 2022 09:26 AM
jhawkeye
May 25, 2022 06:33 PM
djmarch
Aug 9, 2015 05:27 PM
