High Idle when cold
Old Nov 28, 2007 | 08:44 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
High Idle when cold
I know there ar elots of threads about incorrect idle speeds etc but most seem to have multiple symptoms and are on quite different cars.
Mine is a 92 Camaro RS 305 TBI.
All stock except flowmaster muffler and K&N filter.
it will idle at 1000-1500 when cold, but once it warms up it is perfectly normal (about 700 or so). It idled normally for the first few months.
NO other symptoms, and no codes.
Any ideas?
Old Nov 28, 2007 | 09:10 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: High Idle when cold
you answered your own question, it's cold outside, that's perfectly normal
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Im pretty sure its supposed to idle high when its cold. Thats why you have the Idle Air Control valve. it allows the ECM to control your engines idle rpm to warm up.
My car does the same thing. It idles at about 1500 right after start, and slowly works its way down to abou 700 RPM over 5 minutes of sitting. When driving, it idles at 700 untill it gets past 180* then it idles at 500 when fully warm with the clutch in.
Old Nov 28, 2007 | 09:31 AM
Car: 92 Camaro RS
Axle/Gears: Stock
no no no, I live in FL, air temperature is never "cold". I mean when the engine is cold.
I disagree, it should NOT idle at 1500 RPMS just because the engine is not warmed up. Maybe if the air temp is freezing, yes.
But when I go and start it in a minute it will idle high and it is 70 degrees....I do not think the air temp is causing it.
Old Nov 28, 2007 | 09:44 AM
Car: 92 Camaro RS
Axle/Gears: Stock
I do appreciate these points, but just to clarify a few reasons why I don't think it is purely air temp causing this.
Mine started doing it over night. It never did it before (maybe 1000RPM for 30 seconds). The air temp has only dropped from 80 to 70, it is still nowhere near "cold" and mine will idle high all the way to work (20-30mins)!
I have to keep my foot heavy on the brake at the lights all the way, to not rear end people. I don't consider that normal. Unless maybe, like I said the temp is freezing, but it is nowhere near cold.
Old Nov 28, 2007 | 10:43 AM
Damon's Avatar
Throttle cable not allowing the throttle to close fully would be one explanation- could be held up on something, possibly.
If you're talking real engine issues then I'd get a scan tool on it and see if anything's reading odd. Like a CTS (Coolant Temp Sensor) that's reading significantly lower than actual. Or a bad TPS (Throttle Position Sensor).
Last would be something like maybe the IAC (Idle Air Control) unit being bad and not allowing it to idle down, or possibly.... a simple vacuum leak.
That would be my short list.
Old Nov 28, 2007 | 10:47 AM
Car: 1984 z28
Engine: BBC
Transmission: TH400
You should have probably stated that in your initial post. Start with what Damon has mentioned.
Old Nov 28, 2007 | 12:06 PM
Car: 92 Camaro RS
Axle/Gears: Stock
well I TRY to not make every post that long as then no one bothers to read them.
I also did say it is not pulling any codes so I am leaning more towards needing to adjust the IAC or TPS too...rather than something that significant being plain broken...I'll check those and the throttle cable etc...although that seemed fine when I cleaned the TB a few months ago...u never know.
thanks guys.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
86IROC112
Aug 21, 2015 07:20 PM
