Destroyed Oil Filter
Old Dec 18, 2007 | 06:28 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
I seafoamed my car the other day, and I went to change the oil.
I couldnt get the filter off for the life of me, I even did the screw driver method in an act of desperation. Tried channel locks too. Ended up shearing it in half, All thats basicly left of the oil filter is the top part that screws onto the block.
I see about 5 or 6 holes, I tried taking this v-shaped tool I have and sticking it in one of the holes and hammering it lose.. doesnt work. This thing is damn stuck.
A friend of mine suggested maybe taking a drill and progressivly making one of the holes bigger and bigger untill I can some how cut through it enough that I can just pry the filter off the threads.
Im just at a complete loss right now, and the worse part about it, is its like 25 degrees outside and my car is in my driveway almost covered in snow.
I even took wd-40 and sprayed it into the holes hoping to losen the gasket.
I know there are some threads about this problem, but ive never seen anyone say that they got it off. A couple people mentioned that there is 2 7/16th bolts holding the oil filter adapter to the block, but I cant access them.
Old Dec 18, 2007 | 06:33 PM
Re: Destroyed Oil Filter
Very very easy, now that the tin-foil part is out of the way.
Take a chisel or something. Put it on the edge of the plate, at an angle. Cut a notch with it first it necessary. Strike with BFH.
Old Dec 18, 2007 | 06:37 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Alright, going outside and trying that, thanks once again sofaking =D
Old Dec 18, 2007 | 08:23 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
If you haven't got it off that way you could use the oil wrench 5 to 10 dollar tool at a auto shop if what he said didn't work try that.
Old Dec 18, 2007 | 09:27 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Well I tried the chisel thing, didnt work allthough I did get a damn good bite into the top part of the filter. Sprayed pb blaster into the holes hoping it would help break the seal. Not moving a bit.
My dad said that once I get done fixing his car (stupid piece of **** 3.8 liter ford mustang, head gasket lawl), that he would pay to have my car towed and taken to a shop to get fixed. I would rather him not do that considering it would probably turn out to be more expensive than he would want it to be.
berlin305: There isnt enough filter left for me to use the wrench, and I tried it before I destroyed the filter, it still wouldnt move. Thats why I used the screwdriver method then when that failed I used channel locks.
Its weird though, I put the filter on before I put the engine in, and I hand tightened it.. Its like a gorilla put it on.
Old Dec 18, 2007 | 09:38 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
did you put the filter on, sounds like it may be cross threaded...
Old Dec 18, 2007 | 09:56 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Waax, is there enough of the filter left to put a "strap" type oil filter wrench on it ? Also, another idea would be to try using a pair of channel
locks on it . The channel locks I'm talking about are HUGE and about
15-20 bucks. I believe they will open well over six inches and they grip
like a wolverine. With handles nearly 18" long they have plenty of leverage.
Hope you get it off! On a more positive note - I'm sure you've got a few new additions to your "creative cursing vocabulary",
" The secret of life is honesty and fair dealing...
if you can fake that,you've got it made. "
Groucho Marx
Old Dec 18, 2007 | 09:57 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Yeah I put it on, went on with ease and I hand tightened it.
I wish I had a welder, I would make a special tool that went in all 7 holes with a bolt on it so I could just use a socket wrench and take it off =\.
Anyone know if they make those tools?
Groucho Marx
Yeah I used one of those circular metal oil filter wrenches that tightens when you pull on it, didnt use a strap one. I tried using channel locks on it but thats what ended up shearing the filter in half.
Theres not enough material left on the circumference of the filter for me to get a strap based oil filter wrench around.
Haha, yeah, my cursing vocabulary has gotten a little bit bigger because of this expierence, unfortunatly (I swear too often as it is lol)
Old Dec 18, 2007 | 10:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
At this stage, just grab some pliers and tear the remnants out. All that you'll have left is the threaded part (stuck) once you're done. Rip the center part out until you can get to those two bolts. Remove those then just pull the whole thing out. Then you can put it on your bench vise and have some room to tear the thing off.
If needed you might be able to buy a new oil filter adapter, but I doubt those are in stock near you, not really a wear item eh?
Old Dec 18, 2007 | 10:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I bet all he will have to do is loosen the two bolts that hold the adapter on. That will loosen up the filter o-ring and let it come off. Next time smear a little oil on the o-ring and don't tighten the filter as tight.
Old Dec 18, 2007 | 10:22 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Theres nothing really I can grab with pliers, thats why my friend mentioned maybe drilling the holes out bigger untill the outer area of the thing just falls off (the sealing part) and then just undo screw part off the threads.
This sure is a pain in the *** >.<
Old Dec 18, 2007 | 10:25 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
The top part of the filter with the 7 small holes in it block my access to the bolts. I think tomorrow im just going to drill all the holes out big enough to where I connect them all causing the outer part of the filter to just fall off. Then ill be able to unscrew the rest by hand *hopefully, and if not then ill undo the two adapter bolts you guys are talking about, and dealing with it that way*.
Old Dec 18, 2007 | 10:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Oh, I thought by now you've wallowed those holes into nothing. Go for it. There's really little you can screw up at this point. Worst case is you need to get a new oil filter adapter. Give'r some wrecking power man! Release the beast within!
Old Dec 18, 2007 | 10:28 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
If you look at that image, the only part left of my oil filter is the plate that has the seal on it, with the holes.
Old Dec 18, 2007 | 10:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Ok then, open up those holes and remove the oil filter pad by taking the bolts out. If it is cross threaded, get a new one, if the filter comes right off, bolt it back on.
Old Dec 19, 2007 | 05:35 PM
berlin305's Avatar
well if that fails use some vice grips. that might work. just be sure to turn it the right way or ur asking for trouble and accidently cross threading you're oil filter's plug
nevermind my last statement yea sounds like when u put the filter on it cross threaded if you're having htat much trouble. you will need to get an adapter. fyi i would just be on the safe side so that don't happen again. make sure you get some oil on the gasket so it don't get stuck again.
Old Dec 19, 2007 | 06:04 PM
Next possible trick that comes to mind is to make a "spanner" wrench: take a piece of strip stock like 1" x ¼" thick and maybe a foot or so long; drill 2 holes into it at one end, the same distance apart as 2 of the holes in the filter baseplate that are across from each other; put 2 bolts & nuts into the holes in the strip stock; stick the ends of the bolts into the baseplate holes; turn.
I can't believe you couldn't get it off with a chisel.... never seen one that didn't work on, when the edge is exposed.
Old Dec 19, 2007 | 06:19 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
well if you get it off,you can put a new adapter in without the bypass spring in it.
Old Dec 19, 2007 | 06:36 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
+1
Old Dec 19, 2007 | 10:57 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The gasket is stuck to the adapter. I just drive a screwdriver between the filter and the housing when that happens. It will bend the filter (it's weaker than the base) and release the gasket.
Old Dec 20, 2007 | 11:52 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With that method, it sounds like youll run the risk of marring the gasket surface. Gets the filter off, but it may cause an oil leak.
Im also surprised that the chisel method didnt work, especially when it was hand tightened. Did you prelube the seal?
Old Dec 20, 2007 | 09:22 PM
jv9999's Avatar
Engine: 5.7L/350
I agree there is some risk, but I've done it 10 or 15 times and no problems yet. It's usually from fast lube places that gorilla them on without oiling the gasket, or filters than have been on for 50K miles.
Old Dec 20, 2007 | 11:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Must have been the Seafoam.
Old Dec 23, 2007 | 10:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Put a thin screwdriver in one of the holes, and try to pry it down - not to pry the oil filter off the engine, but to try to get the outside with the seal down off the block, then you could:
A) have something to grab onto a twist it off.
B) access the adapter bolts to the block.
Old Dec 25, 2007 | 01:04 AM
L98 Uh_Oh's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7L TPI L-98, Headers, Flowmaster
Transmission: 700R4 w/shift kit
Axle/Gears: Stock, I think...
This may sound stupid and I don't mean to **** you off anymore than you are already at this point, but are you turning the right way? I know lying on your back, with filter right side up, it can be confusing on which direction is loosening.
First time I ever changed oil in a car (when I was like 14), I used the filter wrench to tighten oil filter back on. Duh! Ran into same situation when removing months later. To get off, I used the screw driver method (didn't work), then the large channel locks (worked). But I remember trying to turn the wrong way.
Boy, was I a dumb kid...lol
Also, don't know if this is a good idea or not but maybe take a small butane torch and apply some heat to threaded end. Never tried this but heat works in other applications where stuck rusted bolts/nuts won't come loose. I would ask someone else before trying this method or make sure you have a fire extinguisher very close.
I hope you get it off.
Old Dec 25, 2007 | 09:44 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
So did you get it off?
If not take 2 philips screw drivers that fit in the holes, put a wrench
between them and turn it out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
