INTAKE MANIFOLD HELP!!!! GOIN CRAZY
Old Dec 21, 2007 | 05:22 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
I Have been talking to a few people on helping me choose the right intake for my car. i right now have an 91 rs with stock 305. my plans are headers,exhaust lt1 cam, and go from tbi to carb. i am stuck on what manifold to chiooose. can u guys point me in the right direction.
some are saying this manifold wieand X-cellerator and some are saying the edelbrock rpm. what should i go for? please help me
Old Dec 21, 2007 | 05:35 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: INTAKE MANIFOLD HELP!!!! GOIN CRAZY
watsup? ,my son-in-law ran a holley street dominator,750 holley with no probs.actually made descent power.his was a 91 rs 305 5speed also,plus you have a better cam than he did.later jimmy
Old Dec 21, 2007 | 09:23 PM
Damon's Avatar
Definitely not the Xcelerator. The Performer RPM is a tight fit under a stock hood and it won't bolt to your stock heads without modification.
If you're not changing the basic motor you really just need an entry-level aluminum intake designed for idle-5500 kind of RPM range and easy fit under the stock hood. Oh, and if it would fit the 87-up intake bolt pattern of your heads without modification that would be a plus.
Here's such an intake for reasonable money.....
http://store.summitracing.com/partde...6&autoview=sku
Summit house brand intakes are all made by Weiand but with a Summit logo put on them in place of the Weiand logo.
Old Dec 21, 2007 | 09:31 PM
Car: 88 IROC-z
Engine: LO3 V8 305
why not the xcelerator? my boy told me to get that. now why shouldnt i get that?
Old Dec 21, 2007 | 10:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Didn't you just make this thread over on the carb forum??
Old Dec 22, 2007 | 01:14 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
https://www.thirdgen.org/forums/carb...ml#post3573058
you asked this and already got answers. The rpm is a good manifold for your application, you will probably need a drop base air cleaner.
Old Dec 22, 2007 | 07:02 AM
Damon's Avatar
The Xcelerator is a single plane intake- you don't want that with a mild 305.
I stated why not the RPM. Go ahead and use it if you like, just be aware of the potential issues you will have putting it on your motor and fitting it under the hood.
I will stand by my recommendation, above.
Please don't double-post the same question in multiple forums in the future.
Old Dec 22, 2007 | 03:21 PM
Car: 88 IROC-z
Engine: LO3 V8 305
thanx for the help guys thanx
Old Dec 22, 2007 | 04:41 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
anytime killa,later jimmy
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
