86 Camaro curb weight
Old Dec 26, 2007 | 08:43 PM
skinny z's Avatar
Hi everbody,
Have any of you had your car on scales? My 86 weighed in at 3900 lbs with me (200lbs) although specs I've read suggest thats a bit heavy. More like 3400lbs curb weight plus driver.
A 350 with near stock vortec heads, .028" head gasket and Speed Pro flat tops for 9.97:1 CR, Comp 268H flat tappet cam 4 degrees advanced (200 PSI cranking pressure), 1.6 Pro Magnum rockers, 34 degrees total advance with 12 initial (94 octane), shorty headers with 3" single cat, typically modified 4L60 with TCI Breakaway convertor (2500+/- stall), 3.73 BW posi with 26" drag radials get me a best 13.4@102 with a 1.89 60'. Nice summer day near Toronto. 70 degrees and average humidity.
Seems like everyone else is a bit quicker considering the combinations.
I'm thinking some 1 5/8 long tube headers with 20" long collectors and true duals will bring on the torque when the motor is on the convertor. Should improve the 60'. I'd love 12's but doubt it'll happen.
Suggestions?
Any other weigh-ins?
Old Dec 26, 2007 | 09:30 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
Re: 86 Camaro curb weight
I have an 86 Camaro with T-tops(in case it makes a weight difference) and the title says 3352 lbs, I've never had it on a scale though so I'm not sure how acurate that is.
Old Dec 26, 2007 | 11:39 PM
skinny z's Avatar
Sounds a little light although with all the differant ways they weigh a vehicle (shipping, curb, gross, etc) and all the options (eg. a/c) it'd be difficult to say what the title weight means.
Old Dec 27, 2007 | 02:24 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
3300lbs (without me i think - i walked off the scale as the dude printed the readout and didnt check).
I think if your under 3000lbs thats awesome, thats my goal anyway.
Old Dec 28, 2007 | 10:09 PM
skinny z's Avatar
If what I understand is accurate, then reducing my vehicle weight from 3600 to 3000 (as is your goal) will bring my ET down about 6/10s. One tenth for every 100 lbs more or less.
Question is, where do you lose 600 lbs from a fully streetable car?
Removing the crash bumpers from beneath the front and rear valence and the impact beams in the doors would help a lot but at what risk?
Old Dec 28, 2007 | 10:20 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
My 86 t-top iroc weighted 3600 with me in to the car. So the car wieghts 3340 pounds. Is all stock with a/c except the air pump and fog lights. It has 16" wheels and 245/16 tires. That the same garconer and assiuroc's cars.
Old Dec 28, 2007 | 10:44 PM
skinny z's Avatar
I had the car weighed a second time and the results compare with yours and the rest.
Guess I'm making less power than I thought.
3600lbs
13.4 seconds
102 mph
300 rwhp
375 at the flywheel.
Maybe.
Old Jun 13, 2008 | 07:19 AM
skinny z's Avatar
I'm picking up another Camaro next week and had the title faxed to me. It says an empty weight of 3071 lbs. That's light. Even with half a tank of fuel (60lbs) and me (200lbs) that's only 3331 lbs going down the road. That's 400 lbs lighter than my 86 IROC-Z.
Old Oct 4, 2008 | 07:23 AM
skinny z's Avatar
Right off the four corner scales.
LF 1014
RF 962
LR 865
RR 804
Total 3649 w/ 200 lb driver and full tank of fuel.
My sig is attached for reference.
Old Oct 5, 2008 | 03:07 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
my '85 z28 weighed in at 3260 without me in it, and with a 1/3 tank of gas, on a scale less than 3 months old. The car is totally stock, but with the A/C removed and smog equipment removed.
Old Oct 5, 2008 | 04:19 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
my hardtop stick 89 says 3200 on the door. I guess thats probably no driver empty tank? So i would say maybe 3500 lbs.
Old Oct 5, 2008 | 04:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Race weight, car, driver, fuel etc is how much weight the engine has to move. On a typical street car, I always estimate this at 3500 pounds but depending on options, this can go 100-200 pounds either way. How much a car weighs without a driver doesn't mean much unless you're shipping or transporting it.
My car's race weight is 3042 but it's also a stripped down, gutted out, race car. Trying to strip 500 pounds out of a third gen street car isn't easy. It's easier to make a car faster by making it lighter than by making HP but how much you can remove in a street car is limited.
Old Oct 5, 2008 | 04:50 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
about 3800 with no one in it, they checked the weight at the smog check station
Old Oct 5, 2008 | 10:00 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
Damn I guess my car is a fatass then... the door sticker says 4132lbs with 1/2 tank and 200lb driver lol
Old Oct 5, 2008 | 10:48 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
My 84 Z28 with T-Tops and most heavily optioned came in at 3250 from the smog station. I don't know how they come up with that number though. The back wheels go on rollers, but I don't see how they weigh it.
Old Oct 6, 2008 | 02:58 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
I have a question, like i said, my Iroc reads 3205 lbs on the door. What weight is that? I;m assuming that is no fuel or driver??
Old Oct 6, 2008 | 04:48 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
IIRC the number on the title/door is without any fluids (no gas, coolent, oil, trans, diff, washer etc.). but i am not totally positive on that.
Old Oct 6, 2008 | 08:41 PM
skinny z's Avatar
Absolutely.
Old Aug 4, 2016 | 02:52 PM
Garges24's Avatar
Car: 86 Z28 Camaro
Engine: Sbc 434
Axle/Gears: Currie 9" 4.11's
I just weighed mine today, with me and a half tank of gas it's 3,740 lbs!
Old May 17, 2019 | 11:33 PM
Locotrucker's Avatar
So would a 1 1/2 ton floor Jack be sufficient to lift this car?
Old May 18, 2019 | 09:51 AM
Vader's Avatar
One end at a time.
Old May 20, 2019 | 06:43 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
My 88 Firebird SE sbc. Iron heads Th350 no air
#3530 w/driver.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
