Engine misses at 40MPH
Old Jan 7, 2008 | 06:56 PM
camarod24's Avatar
Car: 1986 Camaro Iroc
I bought an 86 about 2 weeks ago and it is missing but only missing between 35 and 40 MPH. I am not sure where to even start there are a lot of things it could be from what I hear. I tried a fuel cleaner and it didn't help. I was thinking the next couple of things I might try are a new fuel filter and new plugs and wires. Also when I bought the car the air pump has the belt off of it and I was thnking maybe that has something to do with it? MAybe something with the timing? Please help
Old Jan 7, 2008 | 07:14 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Engine misses at 40MPH
are you sure it isn't the torque converter locking and unlocking? factory programming has that happen around 35-40 mph.
Old Jan 7, 2008 | 07:28 PM
camarod24's Avatar
I am not sure. It is REALLY jerky right around there like moving me forward and backwards in my seat.
Old Jan 7, 2008 | 07:33 PM
ljnowell's Avatar
I guess it could be possible that it is the TCC solenoid. Or even the clutch itself. We replace em in the yodas all the time. I wouldnt rule out anything. MAF car?
Old Jan 7, 2008 | 07:34 PM
87zjeff's Avatar
disconnect the electrical connector at the transmission and take it for a test drive to see if it still does it. if it doesn't, you have found the problem. then reconnect the connector.
off subject, i kinda miss norfolk. i was stationed there in the early '90s.
Old Jan 7, 2008 | 07:50 PM
camarod24's Avatar
I can disconnect that and still drive? I am still sort of new to fixing cars and everything I know so far I have taught myself. So a lot of this stuff I am not exactly sure what you guys are talking about. I have an idea but am not sure.
Yeah it is nice having everything near by. What ship or squadron were you with?
Old Jan 7, 2008 | 09:13 PM
87zjeff's Avatar
lol....when i was your age i did good to do a tune up and change oil and brakes.
yes you can drive it for short distances like that. just don't do it for long or at highway speeds. i have mine programmed so that the convertor doesn't even lock until 44mph. the electrical connector is the only electrical connector on the transmission. it is on the drivers side. you just need to jack up the car to get to it. make sure you secure it before you test drive.
i was stationed on the U.S.S. Mount Whitney. was at pier 20 for the longest time then we got moved down to pier 5 at ***. i still have friends in the area that i haven't seen in forever. it sucks to be broke
Old Jan 7, 2008 | 09:25 PM
camarod24's Avatar
I think I will definatly try that. could it have anything to do with the timing?
I am with VAW 123 we just got back from a six month cruise and this car was sort of my present to myself lol. I only paid 1000 for it.
Old Jan 7, 2008 | 10:01 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
just a footnote i'm having the same issue, where it like jerks and jerks but you can power through it? check your fuel filter asap because i put mine off and it was so clogged up it wasnt even funny, now im having fuel pump issues from working so hard to push it through.
Old Jan 7, 2008 | 10:15 PM
camarod24's Avatar
Thanks a lot that is definatly on the agenda of things to do this weekend along with a transmission flush thermostat change and a change of plugs and wires. I can't wait :-)
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
dhonda200
Aug 11, 2015 11:50 PM
