Unported Vortec/carb guys. . .
Old Feb 7, 2008 | 05:16 AM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
I know the Vortecs are popular around here, I'm curious to see just how much power these heads can make. Whats the potential of these things?
Please list your setup and expected/actually numbers. . .
Old Feb 7, 2008 | 09:25 AM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Re: Unported Vortec/carb guys. . .
Im building a Vortec with 10.5-10.8:1, probably the latter, a Lunati 232/242 .510"/.525" 110 lsa hydraulic roller cam, Prof.Prod. Crosswind/airgap intake, 750 Mighty Demon, Beehive valve springs with Titanium retainers.
Motor will be zero decked and balanced, heads milled, but stock bore and stock stroke...block does NOT need bored.
with 4.10 gears and MT ET Street radials, I hope to run 12.0h's or quicker.
Old Feb 7, 2008 | 09:55 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Look for a guy on Nastyz28.com with an unported vortec and BIG solid flat cam. I think he went mid 11's with that setup. (remember how heavy second gens are...)
There's also a handful of members here running non-ported vortecs running quite fast. Two off the top of my head, but only one is willing to share the secrets of his combo.
Old Feb 7, 2008 | 11:20 AM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
You are thinking of the Malibu. He went 11.60's at 114mph. 413ci. 11.3:1 or there about. 244/252 .520/.540 xs282 comp cam, Super Victor, and 750 holley.
3.42 gears and a 4000 stall. 3500lbs.
Old Feb 7, 2008 | 11:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
I'm pretty sure I was thinking of a '79 Camarom, or thereabouts. It was a 383 too. And I think the cam was even bigger then that.
I might be mistaken though.
There was some chatter about the guy being one of the design engineers who helped create the vortecs or something like that...
Old Feb 7, 2008 | 12:10 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
412ci
430 hp, 525 ft/lbs
Old Feb 7, 2008 | 12:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
This is the one I was thinking of
http://www.nastyz28.com/forum/showpo...84&postcount=8
Part of this thread
http://www.nastyz28.com/forum/showth...ported+vortecs
Old Feb 7, 2008 | 12:56 PM
skinny z's Avatar
Check out 'Sledgehammer' in Popular Hot Rodding.
Old Feb 7, 2008 | 02:13 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Nice reads
Old Feb 7, 2008 | 05:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
with the proper cam these heads can run very well.
the typical XE274, 3500 stall, 3.73 and 26" tires at 10:1 is usually good for bottom 12s, maybe high 11s.
Old Feb 7, 2008 | 09:30 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Comp Cams CS XE284H-10 -0.507 int./0.510 exh. lift is my cam
and i got a 3500 stall
Old Feb 7, 2008 | 10:23 PM
Engine: 400
Unless you've had the guides machined you won't be able to run a cam over .480" lift.
Old Feb 8, 2008 | 05:06 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Guides have been machined, screw in studs, everything. My motor runs fine, I'm just curious as to what other peoples setups are running power wise
Old Feb 8, 2008 | 07:53 AM
Engine: 400
Cool. Yeah they sure do make good power for being a factory casting eh? I got my set for 200 bucks.
Old Feb 8, 2008 | 08:29 AM
SteelTownMadDog's Avatar
Last summer, I witnessed a 383 do 430 HP & 460 TQ on a dyno with non-ported Vortecs, 0.520 " lift hyd flat tappet, Performer RPM, & a Qjet. That was also with 112 race fuel because the compression was somewhere around 10.6:1.
Video here; http://www.wildgooseperformance.com/dynorun.html
87v6Bird
Jul 1, 2018 04:12 PM
Antips16
Oct 30, 2015 06:42 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
