91 RS smokes all the time
Old Feb 9, 2008 | 02:23 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I just bought this 91 RS a month ago, I know it has been sitting for 3 or 4 months before I bought it, but other than that it don't over heat. The coolant level is fine. Could it be the EGR valve, smog pump, or the catalytic coverter? Or a combonation of all 3 maybe? I know I had to bolt the tube back on that goes to the back of the smog pump. So if anyone can help me out here......I'm all ears. Also thanks in advance for any help.
Old Feb 9, 2008 | 05:32 PM
camarod24's Avatar
Car: 1986 Camaro Iroc
Re: 91 RS smokes all the time
did you check and see if you have a hole in your exhaust somewhere?
Old Feb 9, 2008 | 06:28 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I have 3 small holes on my passenger side tailpipe right brfore my chrome tip.
Old Feb 9, 2008 | 07:49 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
could be many things , i would recommend a press. check of all cylinders . then a comparison of all . could be rings , valves , not sure , don't think e.g.r. . pull all plugs , press. each cylinder ( 80 p.s.i. ) , listen to intake , listen to exhaust , listen to oil filler cap area ( cap removed ) . intake lk. , intake valve , exhaust lk. , exhaust valve , oil filler area , rings . most common of smoke problems is valve stem seals . take one step at a time , do not panic . there is no such thing as a perfect/total seal . keeping on with your search and questions can only help . good luck ...
Old Feb 9, 2008 | 08:02 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Thanks Tom I will do that and get back here with my report.
Old Feb 9, 2008 | 08:14 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what color is the smoke? Blueish smoke is oil burning, black = running too rich, white sweet smelling smoke - coolant. As tom mentioned valve stem seals are a common source of oil burning on startup, but if its happening all the time it most likely isn't valve seals.
Old Feb 9, 2008 | 08:32 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
It's most definetly white smoke, in a way it smells sweet. My coolant level is fine, it doesn't overheat, there is no coolant in my oil. So why would it be coolant?????? Could you please explain......
Old Feb 10, 2008 | 11:52 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
anybody else?????
Old May 9, 2008 | 05:20 PM
crossfire_Alpin's Avatar
Mine does the same thing to. It blows white smoke but no coolant in the oil, does not overheat, and coolent level is fine.
Old May 9, 2008 | 05:46 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
first is it steam or smoke? i like to take a small window pane or mirror and hold it in the "smoke" if it fogs or gets some condensation you know it is coolant if it doesnt get condensation or the exhaust doesnt feel wet then it is smoke
Old May 9, 2008 | 09:41 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I will try that tomorrow and get back to you on that and let you know, then maybe you could tell what it is.
Old May 13, 2008 | 07:50 PM
dennine2's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I did the mirror thing and it did get alittle condensation on it but not much, so it is most defently coolant? So I have a small crack in one of the water jacket holes in the head gaskets then?
Old May 13, 2008 | 08:22 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
well i just put new head gaskets on my car and is still smoking and come to find out it is the catalyic converter smells kinda odd and smokes all the time so that might be your problem
bryan623
Mar 22, 2021 06:43 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
