383 6.0 or 5.7 rods??
Old Feb 13, 2008 | 10:39 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
was just wondering whats prefered 6in or 5.7 rods also what machine work is involved to the block using a stroker kit? scat or eagle??
Old Feb 13, 2008 | 10:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 383 6.0 or 5.7 rods??
5.56, no machining required. For 5.7 or 6.0, ask your machine shop.
Old Feb 13, 2008 | 10:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
5.7 is more common (ie. cheaper). 6 gives you more room to more easily internally balance the crank if you like. The block doesn't need a whole lot of machining, at least nothing precise. Everything can be done by hand with a die grinder.
Old Feb 13, 2008 | 10:56 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
so i would assyble and rotate by hand checking for clearance and removing m aterial as needed i ws just wondering what was exactly involved. it cant be any harder than rebuilding a gm th trany
Old Feb 13, 2008 | 10:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's exactly it, install the crank, cam and timing set. Then put one piston in at a time, rotating the crank through 2 full rotations checking for clearance at the pan rails, bottoms of the cylinder bores and cam lobes. Disassemble, clearance as necessary. Lather, rinse, repeat.
Old Feb 13, 2008 | 11:02 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
what would you remove material from to clearance for the cam lobes?
Old Feb 13, 2008 | 11:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't want to remove anything from the cam lobes. If you've got contact there, you can maybe clearance the rod bolts (not a preferred solution). If you use cap screw rods, you can safely remove some material from the rod, or the rods may already be clearanced for stroker use. If you still need more room, you can use a cam ground on a smaller base circle.
Old Feb 13, 2008 | 11:14 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
of course you dont want to remove from the cam!! most likely the rods will be pre clearanced being that its a rotating assembly stroker kit
Old Feb 13, 2008 | 11:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, chances are, but you'll still need to check.
Old Feb 13, 2008 | 11:19 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
that'd be why i ask'd
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
IROCtometal
Sep 20, 2015 11:08 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
IROCtometal
Sep 9, 2015 10:01 AM
