350 rebuild
Old Feb 29, 2008 | 02:20 AM
bigtownsend's Avatar
Car: 1982 camaro z28
Engine: 305ci cross-fire injection
Transmission: turbo 350
350 rebuild
just a quick question... how hard is it to rebuild a 350 by yourself?
Old Feb 29, 2008 | 05:17 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: 350 rebuild
Pretty easy, you might need a drinking partner though
Old Feb 29, 2008 | 05:50 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Re: 350 rebuild
Get a book , jegs and summit have them for less than $ 20 and will really help you get started , the torque specs , calculations , end play specs , gaps and clearances are a refrence you can keep forever .
Old Feb 29, 2008 | 06:01 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: 350 rebuild
its not to bad to do you need a good book. and take your time..the main thing is a good meachine shop..for the block work..
Old Feb 29, 2008 | 07:11 PM
82taluver's Avatar
Car: 1991 GTA
Transmission: M5
Re: 350 rebuild
Not too bad i think putting them back in is more of a pain! The most important thing is CLEAN CLEAN CLEAN make sure your work place and parts are clean as can be, dirt is the number one enemy! You can do it and theres no better feeling than turning the key and all your stress and anger be replaced by the music of a fresh v-8
Old Feb 29, 2008 | 08:17 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: 350 rebuild
wrap engine in large plastic contractors bag to keep clean.
Old Feb 29, 2008 | 11:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 350 rebuild
You'll need a handful of tools, but nothing too outrageous, dollars wise.
feeler gauges, plastigauge, rod bolt boots, ring expander, ring compressor, torque wrench, 9/16" and 5/8" sockets (and that's basically the only sizes you need....). A dial gauge and magnetic base are nice also.
Vizards book on rebuilding an SBC is a great one. Pretty dated, but luckily the 350 chevy is unchanged
Goes into all the tiny little details that you won't find elsewhere.
Old Mar 1, 2008 | 09:42 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: 350 rebuild
John Lingenfelter's book at amazon.com $10 also has lots of detail.
modifying small block chevy engines
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
