What’s that thing below the AC compressor called?
Old Mar 24, 2008 | 11:27 AM
Connan1's Avatar
Car: 1992 Camaro RS
Engine: 5.0 Liter V8 TBI
Transmission: 5-speed manual
What ever it is, it is not spinning. Here is the story: Early on Sunday morning (very cold) I start the engine and a loud screeching sound is coming out from under the hood. I let it run to see if it will clear up. It doesn’t. In fact, I start to smell burnt rubber, so I cut the engine off. I come back to the car later that day and remove the serpentine belt so that I can check which accessory wheel is not spinning and screwing up my belt. The only wheel that doesn’t spin when I go to spin it with my hand (other than the one coming from the engine that drives all the others) is the one below the AC compressor. It’s a 1992 Camaro RS with a 305 TBI engine.
(1) What it is called or what is its function?
(2) Do I have to remove and replace the whole unit or can I just remove and replace the wheel itself (like I did with the tensioner pulley wheel)?
Thanks for any help
Old Mar 24, 2008 | 11:41 AM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: What’s that thing below the AC compressor called?
its the smog pump you have to replace the whole pump,if you dont have emissions check you can get a smog celete pulley and leave it off,later jimmy
Old Mar 24, 2008 | 01:35 PM
ljnowell's Avatar
Or you could probably just get a shorter belt and reroute it. No cost for pulley, and since you smoked the belt, you need a new one anyway
Old Mar 25, 2008 | 06:00 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Actually if he re routes his belt he's going to need a longer belt,if you want to re route it try goodyear part# 4060967,this will keep all your accesories turning in the direction they should,or you have to change your smog pump wich is very easy to do as well.
Old Mar 25, 2008 | 06:08 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Mine did the same thing. It cost like $50 for a rebuilt one which is probably cheaper than the "delete" pully. It's not much of a load on the motor. The fan on the alternator probably takes more HP to run.
Old Mar 25, 2008 | 07:46 PM
Connan1's Avatar
Car: 1992 Camaro RS
Since I have emissions inspection coming up this year, I decided to put in a rebuilt smog pump. Pretty easy job to remove and replace the pump. It cost me $80 bucks which I thought was kinda high, but of the 3 local parts stores I called to get a price, one didn’t answer the phone, and the second guy sounded like he didn’t know what a smog pump was, was really there only to draw a paycheck, and he couldn’t find it on the computer he was using, so I paid the $80 b/c it was convenient and the guy knew what I was asking for.
Thanks for your help guys.
PS: If anyone wants to just omit the smog pump: https://www.thirdgen.org/serpentine
Old Mar 25, 2008 | 08:15 PM
ljnowell's Avatar
Whichever way it goes, point is the same. He already needs a new belt, so just buy the right one and forget the delete pulley. Or replace the pump and have all of your emmisions equipment working properly.
Old Mar 25, 2008 | 09:52 PM
1montess's Avatar
take the crap out of there, get rid of the A.I.R. tubes and plug the holes in the manifolds, and enjoy the increased response in your engine!
TheExaminer
Aug 25, 2015 07:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
rh76camaro
Aug 15, 2015 12:48 PM
