running with no exhaust bad?
Old Apr 12, 2008 | 11:26 AM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
i just pulled my camaro into the garage and not having enough time to try it out last year since the engine was put in just before winter, i want to go check how everything is running on it, i want to see how the engine pulls and if tranny shift good. thing is i havent put an exhaust system on yet and don't plan on putting one for a thew months it just got the exhaust manifoils, will i screw something up if i go try it out like this, i heard i could bent a valve or something along those lines, i ain't a pro in mechanics soo thats why i am asking. I still have to put on my intake manifoil and after that it should be good to try out. Any opinions?
Old Apr 12, 2008 | 12:08 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: running with no exhaust bad?
define no exhaust...no headers? or just nothing from headers and back? running open cylinder heads not only will give you an ear ache but theres nothing to help scevenge exhaust gasses and on a small scale will hurt power. if you have a set of headers on it and nothing else you'll be fine. it won't help and it won't hurt either.
Old Apr 12, 2008 | 07:06 PM
Transmission: th350
Its only got stock exhaust manifoils (headers) on right now. I just want to burn maybe a 1/2 tank of gas with it to see if everything is working good.
Old Apr 12, 2008 | 07:17 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
1/2 tank!!...ur gunna have a migrain after that! lol
Old Apr 12, 2008 | 07:24 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'd worry about frying something with all the hot gas getting spewed right under the hood.
Old Apr 12, 2008 | 07:29 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
i took mine on a 100 mile trip with open 2210 long tubes to get my exhaust put on. I was behind the guy driving my car and it wasnt loud at all unless he got on it.....but inside the car is loud! cause the headers are right under your seats.
Old Apr 12, 2008 | 08:10 PM
Transmission: th350
well i know its lound hehe i fired her up at 1AM before i stored it after everything was hooked up, My neighbours didn't like that very much lol
-----> http://www.youtube.com/watch?v=SrNEvdjHl0U, Its fun inside the car the floors shake, feels like i have a 454 under their hehe. I exagerated their a bit not a full thank of gas their but a good 30min to an hour of run time.
Old Apr 12, 2008 | 08:17 PM
Transmission: th350
and o yha i already did fry somthing, fire caught on the starter wire hehe. Its cool now i ran the wires somewhere else and that won't happen again
Old Apr 13, 2008 | 06:49 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if you have long tubes or stock cast iron headers/manifolds on you should be fine aside from the noise issues and burning stuff, but if u have shorties on you could bend/break the valves due to cool air hitting them after it is run
Old Apr 13, 2008 | 10:29 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Can anyone varify this? 'cause I was gonna have to run my t/a to the exhaust shop, with open (shorty) headers. If this is the case, I will trailer it down their.
Old Apr 13, 2008 | 10:51 PM
ljnowell's Avatar
Old wives tail. As long as you have headers on it, you are fine. Just make sure nothing is in the way to catch fire.
Old Apr 13, 2008 | 11:35 PM
Engine: 383
It's not an old wives tail... i bent 3 exauast valves driving to the exauast place W/ ebay specal shortie headers (1 5/8 pri, 2 1/2 colectors) on a set of stock 70's era 350 heads, about 3 or 4 years ago, it was my excuse to go to trick flow heads, but it was also Jan in NJ, W/ snow on the ground, so that could have hade somthing to do W/ it, but the fact is it can happen.
Old Apr 14, 2008 | 02:05 AM
ljnowell's Avatar
The fact is, it didnt happen from the headers. That happened from an outside issue. Why would it be ok to run manifolds, but not shorties? Manifolds have way less piping after the exhaust ports. Heat dissipation is a non issue with a header installed also. I have broke in and road tested tons of cars with shorties only.
Old Apr 14, 2008 | 04:59 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i would think manifolds would have a greater chance of warping valves.. heard it before but i only run LT's..
Old Apr 14, 2008 | 01:42 PM
Transmission: th350
ohhh, i am having trouble, just replaced the intake manifoils with an edelbrock performer and its not running good at all. SOunds like its not firing on all cylinders. I got my timing pretty close i am 100% sure, all my firing order has been checked, i don't know what it is. Their is a vacuum line that goes to the coil, does that have to be in for it to work good?, I didn't put it on cause i didn't change this weird shaped thing that sticks out the intake, their is something in its place to seal it don't know if you know what i mean but, any ideas where i f~~~ up?
Old Apr 14, 2008 | 05:26 PM
ljnowell's Avatar
You have a vacuum leak and/or a timing or spark plug wire problem. Make sure the wires are right and the timing is in check. Check for vacuum leaks.
Old Apr 14, 2008 | 07:32 PM
Transmission: th350
ok, i know its definatly closely timed cause i braught the #1 cylinder up to top dead center, i then checked my firing order and completely ridid it to be sure it was all correct. It has to be in the vacuum somewheres, but where?, like i said, does anyone know about that vacuum line that commes of the coil? must it be plugged in order for it to work?, thats the only thing i can see at the moment where its loosing vacuum. it also backfire like a b**** sounds alot like something wrong with my firing order but i wne on the internet and got one for a small block chevy. does a 350 have the same firing order as 305?, This is an lg4 out of an 81 camaro incase you guys don't know. I also changed the coil piece that spins their don't know quiet what its called the white piece, i accidently broke it taking it out, i had a spair coil and just took that piece and put it on the one i broke, only thing is its an accel supercoil that i have on and i took the piece of an ac delco one, pretty sure its the same though
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
Bradsaundry
Aug 12, 2015 12:34 AM
