how to varfy a crank is forged?
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I haven an engine I aquired and the previous owner clames it has a forged steel crank, how can I varify this?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: how to varfy a crank is forged?
The oil pan will have to be off. If it's a factory crank, it will have casting numbers on it. You can also tell by the parting line on the crank. If it's an aftermarket crank, it may be harder to tell.
Engine: 383
the engine is apart across my garage, where is the casting # on the crank, and where can i look it up at?
Car: 87 IROC L98
All crankshafts have a casting number located on one of the rough finished throws or counterweights towards the front of the crank.
Forged crankshafts are easily identified vs cast because a forged crank will have a wide parting line running down the length of the crank, while the cast crank has a thin parting line.
Look for a casting number similar to a head or block casting number.
Engine: 383
ok...got the casting number....3932442...hopeing it is a forged one
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Best way is by casting number like previously said, or parting line, but dont forget about sound, hit is with a wrench a nice ring is usually heard if its forged....
Engine: 383
damn....oh well...i guess i need to try to find a new crank....grr this build has taken too damn long...i just want it to be over with, thanks for the info guys...anyone know how much a forged crank uasally run used...i see them in summit for like 650 or so
Car: 1991 Z28 1LE
Transmission: 4l60e
how much hp and what rpms are you looking to run?
the scat 9000 series cast crank is rated for 7500 rpms and 500hp, but ive seen some 600 to 700hp builds with them, and are a bargain at about 180 bucks
Car: 87 IROC L98
3932442 cast crank was used in 1969-1985 305's and 350s. Large journals and 2 piece rear main seal.
I'd run with what you have. It'll be a lot cheaper. If you buy a new crankshaft, you'll have to get your rotating assembly balanced. It depends what your goals are with the engine. Have the crank magnafluxed. If it's cracked, then buy a new crankshaft.
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
