84 Firebird V8 won't start- No dash warning lights
Old Apr 26, 2008 | 12:08 PM
lithium350's Avatar
I have an 84 Firebird SE with a 350 and carburation. (Aftermarket 350, but basically a mid-eighty's GM 350.)
I hadn't driven the car all winter and I was getting it going again. I had to get a new battery, and on the first try the car started up and ran like a champ. I turned it off to check the oil again etc. and now it won't start anymore.
When I turn the key to the on position the dash warning lights do not come on although the headlights work strong. There is also the tic,tic, tic, tic, sound coming from the carburator (I think it is the fuel pump priming up)
When I turn the key I just get the one time clunk sound of the starter, not a crank, crank, crank sound like its really trying to start.
Any ideas- I would just say it is a bad started but no dash warning lights is throwing me off.
Thanks,
Sean
Old Apr 26, 2008 | 01:46 PM
MarkimusPrime's Avatar
Re: 84 Firebird V8 won't start- No dash warning lights
That happened to my car once...it was a bad starter.
Old Apr 26, 2008 | 02:21 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sounds like the starter, not sure about the dash lights, try smacking the starter with a hammer while having someone turn the key..
Old Apr 27, 2008 | 09:58 AM
lithium350's Avatar
I tried the old Hammer trick. The starter is in a bit of a tough spot, so maybe I wasnt getting a great wack at it, but I am still concerned about the lack of dash warning lights.
Anyone have any ideas?
If it warms up again, (frigging Wisconsin is back in the low 50s today) I will probably just replace the starter and see where it gets me, but I would love to hear ideas about the Dash Warning Lights.
Old Apr 27, 2008 | 10:12 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by lithium350
..., but I would love to hear ideas about the Dash Warning Lights.
Loose /bad connection where the wires connect to the starter would explain both symptoms...
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
86IROC112
Nov 7, 2015 06:50 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
