Plugs fouling on right side?
Old May 5, 2008 | 07:01 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My plugs are fouling on the right side of the engine but not on the left. What would cause this to happen?
Old May 5, 2008 | 09:22 PM
Damon's Avatar
Re: Plugs fouling on right side?
All 4 of them? Intake gasket leak into the lifter valley area- like the gasket slid down too far as the intake was dropped on. Worn out rings or valve guides/seals would be a heluva conincidence to take out only one bank of the engine and have no effect on the other.
Old May 6, 2008 | 10:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What intake manifold?
Old May 6, 2008 | 08:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The valve seals are brand new.
Old May 6, 2008 | 08:28 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
oil fouled or gas fouled?
Old May 7, 2008 | 10:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
They were all covered in carbon.
Old May 7, 2008 | 10:14 PM
Car: 91 RS
Engine: 350 vortec
are you burning oil?
Old May 7, 2008 | 10:29 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes, occasionaly it does smoke on start up even though i just put brand new valve seals in it.
Old May 8, 2008 | 12:35 AM
Sonix's Avatar
Car: 1982 Trans-Am
So, what intake manifold is on it?
What was done to the car recently? Did this just pop up out of nowhere?
Old May 8, 2008 | 06:51 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Stock TPI manifold. I just put a motor into the car and got it running. While the motor was out I put a cam in it, full gasket set and valve seals. The other day I just decided to take a look at the plugs and that is when I noticed them getting fouled.
Old May 8, 2008 | 11:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Then I agree with Damons idea, intake gasket could have slid easily.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
