Center Bolt heads to regular heads?
Old May 13, 2008 | 03:01 PM
pyrofire127's Avatar
So i have '88 tbi centerbolt heads (valve covers) and i was wondering if i could covert them to the regular heads?
Im tired of center bolt heads and i've been told by many poeple that theyre normally pretty crappy and tend to leak oil alot.
I assume it just easy bolt on the new set, but im just making sure before i got out and buy a brand new set of heads haha
Thanks!
Old May 13, 2008 | 03:17 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Center Bolt heads to regular heads?
you got it backwards the older style perimeter heads are notorious for leaking oil the newer style(centerbolt) is good for sealing just change your gasket with a rubber felpro replacement and dont worry about it.
Old May 13, 2008 | 03:53 PM
Really? i head the opposite.. but maybe i've got it wrong.. haha
I just found out that the valve covers i have are made out of some crappy tin material and i should by thicker aluminum ones that wont warp under pressure.
Old May 13, 2008 | 10:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Vipershark is right - the 'centerbolt' design was GMs cure for leaky valve covers, and it does work. Just get a good set of rubber gaskets, and make sure your valve covers sealing surface is straight, and you should be good to go.
Old May 13, 2008 | 10:36 PM
well i bought and switched out the old gaskets a while back and that didnt stop it, but i think the previous owner maybe wayyy over torqued the bolts to where it bent the shape of the valve covers maybe??
Old May 14, 2008 | 03:01 PM
Engine: LO3
are the covers chrome plated? what type of gasket did you get?
Old May 14, 2008 | 03:18 PM
Yes they are chrome plated. and they were felpro (sp?) rubber gaskets. someone told me that i need to get some thicker style valve covers, mine right now are really thin and made out of a tin like material
Old May 14, 2008 | 07:01 PM
Air_Adam's Avatar
Thicker aluminum ones help, as they are more rigid. GM also makes a composite set that was on the LT1/LT4 Corvette engines.
The tin valve cover, stock or otherwise, are pretty flimsy and warp easily if overtorqued - thats when they leak. Otherwise, they won't leak with a good gasket.
Old May 14, 2008 | 07:37 PM
sweet then that'll be my next thing to buy haha
Thank you!
Old May 15, 2008 | 04:30 PM
Engine: LO3
try scuffing/sanding the chrome out of the gasket groove if its in there. that cause most of anything to leak.
Old May 15, 2008 | 05:17 PM
really? niceeeeeeee ill try doing that soon THANK YOU!
355tpipickup
Aug 25, 2015 12:54 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
blackd-out z28
Aug 15, 2015 08:18 PM
