Best way to disable a car?
Old May 16, 2008 | 08:16 AM
Spitzfiya's Avatar
What is the best way to disable a car for long term storage to prevent theft?
Like under the hood, what can you disconnect that will prevent the car from starting that is relatively hidden.
I know you can pull the dist. wire, but i need some more ideas
Thanks.
Old May 16, 2008 | 08:37 AM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Best way to disable a car?
Thanks.
u could pop out the fuses and take out the battery
Old May 16, 2008 | 08:40 AM
mean57's Avatar
Car: 87 gta
on firebirds there is a fuse near the battery that if removed will shut down computer. you will know the right one it's a blade fuse in its own housing. when pulled and key on there will be no engine light and car will not start.
Old May 16, 2008 | 09:51 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Disconnect Battery cables, battery, take the fuse out that was mentioned, you can also take the wire out that goes to the coil, if yours on not in the cap. Take out the rotor, ummm.... Disconnects throttle, or just the pedal, take out clutch button behind pedal (stick). Unplug wires that go into dizzy. Disconnect fuel pump, drain tank, Hell, you could even take ign wires if you want. There are TONS of ways to make sure no one can take the car.
Old May 16, 2008 | 09:58 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i would remove the fuse to the computer, disable the clutch (as previously mentioned) and disconnect the fuel pump. i think with those three it wouldnt go anywhere
Old May 16, 2008 | 10:48 AM
Car: 1992 Camaro RS
Engine: 305 TBI
no ones gona be able to figure those all out if some one did try to steal it they may figure one out then just think the car didnt run and thats y its in storge
Old May 16, 2008 | 11:14 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Maybe install a fuel pump cutoff switch and have it hidden.
Old May 16, 2008 | 11:30 AM
Guest
Guest
Posts: n/a
A hidden fuel pump cutoff is nice. You could always take the steering wheel.
Like anything, its not prevention, its deterrence. Make something else appear to be the easier target and they might leave yours alone. But do all those, and it will still be easy to hook+go.
Old May 16, 2008 | 12:46 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'd pop the dist cap, take the rotor, and put the dist cap back on. Could also pop the shift plate off and disconnect the shifter connector.
Or take the computer out.
Old May 16, 2008 | 01:11 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Put it on cinderblocks. Noone steals a car without wheels, heh.
Old May 16, 2008 | 01:49 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Put one of those big yellow wheel locks or clamps on it (the kind the police put on a car).
Old May 16, 2008 | 02:08 PM
Car: 1992 Camaro RS
Engine: 305 TBI
ya deterrence help alot cause with my camaro i would find things telling me people where tryin to ge t in my car then i gota club and no one tryed to steal it since
Old May 16, 2008 | 02:11 PM
dariel's Avatar
is there a website to purchase these
Old May 16, 2008 | 02:34 PM
afida15's Avatar
haha if your car is a auto matic you can take the shift cable off so they cant shift it into gear and wont even be able to roll it out lol
Old May 16, 2008 | 02:42 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Sure, try this link http://www.tirelock.com/
Old May 16, 2008 | 03:14 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
If I wanted to help prevent my car from being stolen from a storage unit.
I would disconnect the fuel pump at that connector in the back of the car that is behind the rear seat area.
Then order a wheel boot or two, or take the wheels off and put it up on blocks.
Like it has been said, that won’t prevent a flat bed tow truck, but will prevent the old smash and grab.
The goal isn’t to prevent car theft that is impossible; the goal is to make your car not worth the effort.
P.S. If you are going to store your car in a storage unit, find one in a decent area.
Old May 16, 2008 | 06:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Remove the battery, unplug the coil wire.
Old May 16, 2008 | 07:32 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i know all about the hook+up and tow... tard came by my house in the middle of the day with a flat bed and grabbed my camaro and ran... thankfully i have the most friggen nosey neighbors in the world... got the car back in 3 hours...
Old May 16, 2008 | 09:26 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Someone with a tow truck will just steal it out from under you? I've seen repo men do that.
Old May 16, 2008 | 09:31 PM
Car: 91 RS
Engine: 350 vortec
no someone called and told the tow truck that they owned the car and wanted it towed to the scrap yard cause the engine was blown.... should have seen the tow guys face when i showed up with the keys and fired it up... it was sorta like please dont call the cops...please...
Old May 17, 2008 | 11:16 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
seriously, this is the best way. If the car is in long term storage, it should not be sitting one the tires anyway. the tires will get flatspots. Just put the car on jack stands or blocks, take the wheels home. Take the battery too, it will just die in teh car anyway. if you feel ambitious, and have the tools, take the steering wheel.
Old May 17, 2008 | 12:53 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Glad you arrived to stop them. I can just picture their faces when you showed up. LOL
Old May 17, 2008 | 01:18 PM
Vader's Avatar
Park it in its space, turn the front wheels (to make it hard for a flatbed haul-away), lock the ignition/steering column, and take the wheel:
Even if someone breaks out the steering column to defeat the ignition and steering lock, straightening the wheels is going to be pretty tough.
Old May 19, 2008 | 03:47 PM
Spitzfiya's Avatar
Hey man that sounds like a good idea...I looked for this fuse the other day but have no idea what i'm looking for...do you have a picture? can you explain it in detail?
Also where is the ignition coil wire everyone talks about? I have no idea what it looks like...
help!!
Old May 20, 2008 | 08:32 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
ditch the driveshaft
Old May 20, 2008 | 10:08 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Switch the coil wire in the distributor cap with a plug wire.
It all looks the same.
Leave the keys in the car.
The car will not crank but will fire intermittly.
Thief will think the car is broken and in the shop for repairs.
Old May 20, 2008 | 10:44 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
My car has something nifty the previous owner wired up for it. You cannot start the car without pulling the headlight **** out which obviously turns the headlights on, The horn will sound if you turn the key and not pull it out, you can drive with the headlight **** pushed in like normal. I cant tell you how many times i forgot to tell mechanics to do this and i get phone calls saying "how the hell do you start your car". its simple and along with the other mentioned tactics it works for anti theft all season.
And oh, dont be stealing my car now. lol
Old May 20, 2008 | 10:50 PM
SDIF's Avatar
Saber,
Thats the best trick I every heard of!!!
I think I will do that with my cars just for fun!
Old May 20, 2008 | 10:52 PM
Car: 1992 Camaro RS
Engine: 305 TBI
first we' have to get the key
Old May 21, 2008 | 08:58 AM
Saber's Avatar
Originally Posted by SDIF
Saber,
Its pretty interesting, i have been meaning to see how its wired up but i keep forgetting to when i have my dash apart. PLus it works very well, and considering out cars were once the most stolen cars in america i would think its a good investment. I though it was a factory anti theft system untill a month ago, plus i told my insurance company about it an they gave me a discount. They counted it as a premium anti theft system or something like that.
Old May 21, 2008 | 09:34 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
How about a car alarm or the club. i'd go with that cause it's the easiest and car alarms make you look cool when your walking away and you arm it in front of ppl especially hot chicks. I don't worry about ppl wanting to steal my cars cause my saturn is a pile, they can have it, and my formula has a fuel pump switch. however i have had things stolen out of my cars. some kid stole my leather jacket and my curve colone.
It's funny, when ever i get insurance set up i always lie and save money. i always tell them i have a car alarm, daytime running lights, all kinds of air bags, yata yata..
Old May 21, 2008 | 10:52 AM
Car: 1992 Camaro RS
Engine: 305 TBI
thats cool i need to rig up somthin like that and i didnt know u could get a discount for that thats awsome
Old May 21, 2008 | 11:40 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Your car would be like the house Richard Pryor bought in the movie "Moving."
No spark plug wires, no spark plugs, no distributor, no shifter, no steering wheel, car on blocks.....
I would recommend one of these for any F-body fan: http://www.ravelco.com/index.htm
Old May 21, 2008 | 12:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should remove the battery anyway when storing long-term, so start there.
After that, make it hard to tow like Vader suggested. Removing the driveshaft would just make it easier to tow away.
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
